Question about Akai LCT2060 Television
Akai leisure 2111 TV
Picture coming too snowy..snow is also fluctuating..i changed tuner even then problem persists
I was doing some electrical work in my house, I disconnected all power source.
when I connected the power again, my picutre is not coming in at all on my akai 42 inch plasma.
it looks snowy, and jumps around theres adio but no picture what do i do?
Posted on Oct 18, 2008
  • 30 Answers
Try to check the video section, the diode and the capacitor.also the transistor>
Posted on Feb 02, 2008
MY SAMSUNG LCD TV MODEL LNS4695DX HAS A SNOWY PICTURE CAN SEE PICTURE BUT IS VERY SNOWY I TRIED ALL INPUTS WITH CABLE DVD AND A GAME SYSTEM BUT NOTHING CHANGES AND THE WIERD PART IS WHEN I HIT THE MENU...
The OSD comes from a different area---if on all inputs it is on a board that processes all signal in the set--tuner,AV etc
You might want to Google the model number with "parts" to come up with a list of the boards and prices if possible for them.
Dec 04, 2012 | Toshiba Televison & Video
No picture
I can suggest unplugging the TV and leaving it off over night. This will do a power reset and may correct the problem. If not the only way to determine the problem with the TV is testing the circuits. For a simple repair you can expect to pay in the ballpark of $100 for the repair.
Hope that helps.....
Aug 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
Snowy screen
Hello, The snow is due to a tuner failure, this can only be repaired by replacing or repairing the tuner itself. Your post shows model number PV-DM2793, and the tuner part number is ENG36715G. It's available from several electronic part stores, try johni@ued.net, there is one still available there. The tuner is located directly behind the cable connector(threaded connector)located in the rear of the TV where the cable or antenna connects to, it solders vertically into the main board.
Apr 20, 2010 | Panasonic PV-DM2793 27 in. TV/VCR/DVD...
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Feb 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Akai LCT2060 Television Logo
173 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
