Question about Samsung RS2534 Side by Side Refrigerator
Refrigerator will not maintain proper temperature
Freezer is maintaining proper temperature, but the refrigerator is not going below 50 degrees.
  • jgrimstad May 11, 2009
    What if there is no power to the fan in the refrigerator?
  • Anonymous May 19, 2009
    freezer is set at right temp but fridge is at 18.19 c and changes to 7.5.8 on its own ice inside fridge can fridge be turnd off independantly.
  • Samsung Master
  • 5,568 Answers
Check in the back of the fridge section; there is normally a control that is provided for 'balancing' the cold air between the two sections. That coolled air is distributed by a concealed fan that may not be running; you should be able to ear or feel the air movement when the unit is in a cooling cycle.
Posted on Apr 19, 2009
  • edratika juvil Aug 25, 2011
    after changing the control .. there's still no changes at temperature... what can be the cause?
  • Steve Allison
    Steve Allison Aug 25, 2011
    If there is no cold air being moved to the fridge from the freezer by the distribution fan, it will not get properly cold but the freezer will seem either normal or somewhat colder than usual.
    Suggested temps for the refrigerator are 35-40F and you don't gain anything below going -5F in the freezer. Most combination units have a 'cold-control' which affects the freezer, and a second which determines how much cold air is sent to the refrigerator. These often will require some fiddling to get the balance correct between the two chambers.
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Tip
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
on Dec 24, 2010 | Refrigerators
Samsung model#rs2577bb freezerworking good refridgerator not maintaining temperature
Not really a permanent solution for Samsung refrigerators with a evaporator inside the fresh food section. You will need to remove the shroud housing the evaporator and clean out the drain opening along with removal of any ice buildup. User Manual HERE
Here is a link to a troubleshooting page that covers your model=> HERE You need to clean and make sure the sensors at base of evaporator are clean and function properly. Also insure condensate drain below evaporator remain clear of blockages ice/gunk. Parts breakdown can be found HERE. I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 12, 2014 | Samsung RS2534 Side by Side Refrigerator
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
The refrigerator is not cooling enough. Even though I turn the dial up to the maximum 7, the temperature will not go below 50 degrees. I need to maintain a temperature below 47 degrees.
There could be two reasons for this
The thermostat is not working properly - replace the thermostat
There is a small refrigerant leak and the fridge cannot get cold enough - you will need a technician to find the leak and regas the fridge
Mar 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
My refrigerator cant maintain cold and freezer temperatures
check and see if the doors are closed good
Mar 31, 2009 | GE Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer not staying cold
thermistor has worned out so please change the thernistor then you ll find the temperature gets maintained in 0 degrees......
Sep 10, 2008 | GE PTS25LHP Top Freezer Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
665 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
