Tub filled with water. It's not washing, rinsing,
Tub filled with water. It's not washing, rinsing, spinning, draining, nothing. Indicator light is on, just not doing anything.
    Sergeant:
    Champion:
  • 245 Answers
Looks to me ur timer or programmer is faulty possible needs replacement or looked after from a tradesman.....call manufacturer for help
Posted on Apr 19, 2009
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
Top Washing Machines Experts
