Question about HP LaserJet 1320 Printer
HP Laserjet 1320 - Acrobat problem in XP
OK this one is doing my nut. I have a networked HP LJ1320tn on a W2003 Server which prints PDF's fine however, try printing PDF's from an XP workstation and it hangs up Acrobat. Have tried both the PCL6 and PS drivers but cannot resolve. Anyone had this issue?
  • briser Sep 20, 2007
    Done that and even recreated the printer a few times, changed most settings etc - it is a timeout issue of some kind (leave it long enough and every so often it prints, other times just breaks Acrobat).
    Update: Ended up downgrading to the 1200 driver and at least it will print PDF's but incredibly slow. Not impressed.
OK, have this printer at work, it is pretty good, not top of the line but economical. Had an issue with PDF files printing VERY VERY SLOWLY from my XP machine. I spent probably a total of 3 hours troubleshooting, and figured out the following...
Open a PDF doc, and when you go to print it, make sure under Advanced that the box beside print as image is NOT marked. This slows down the printing time A LOT. Some printers need to have the "print as image" box checked - we have a large all in one machine that will not print PDFs unless the box is checked. But not this monster... I also had to reinstall my driver and use the PCL6 driver.... hope this helps anyone that may be pulling their hair out over this.
Posted on Apr 23, 2009
  • 163 Answers
Please reinstall the printer driver and also reinstall your window
Posted on Sep 19, 2007
SOURCE:
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
I have a iMac G5 with 10.4.1. I try to print coupons on my hp laserjet 1320 and they stay in the que. Word docs print fine but any time i try to print any kind of coupon from any site, it messes up the...
If you are printing PDF coupons, that is probably the case, you need to upgrade the memory on the printer if you want faster printing on those types of documents.
Mar 22, 2011 | HP LaserJet 1320 Printer
Printing problem (local and network) only with pdf
PDF files are designed to be small on the computer and are uncompressed when sent to the printer. The size of the PDF is filling up the memory on the print server causing it to crash.
make sure you have the latest printer drivers.
heres a work around if the drivers didn't fix it. check "print as an image" from within printing options in Adobe Acrobat (you gotta go to "advanced" to find that check box), and then it works fine.
Apr 06, 2010 | HP P2035N LaserJet Monochrome Printer
Printing problem with HP laserjet 1320
Hope this helps you troubleshoot it.
Link
Regards.
Nov 18, 2008 | HP LaserJet 1320n Printer
My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Sep 16, 2008 | HP LaserJet 1320 Printer
Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Aug 17, 2008 | Emulex NetJet (NJ01B-NTplus) Print Server
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Problem HP 1320 not responding
Try changing to a new USB cable
Jan 31, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
502 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
