Question about Scunci 52067 Handheld Steam Vacuum
Heats up but won't steam
We bought the scunci a couple of eyars ago. i plugged it in last night and it heated up but steam wouldn't come out of the hose. i checked the hose and it was clear. could you give me some ideas of why it wouldn;t work.
  • 3 more comments
  • Anonymous Dec 22, 2007
    My steamer also heats up but will not steam. I can't find my owner's manual, and need to know what to do to fix this problem. I tried poking a long metal rod in the hole, in case it was clogged, but this did not help.
  • 1784 Jun 05, 2008
    icleaned everything it gets hot but steam will not come out
  • Anonymous Jun 20, 2008
    I removed all screws except the ones on the bottom (use a mini screwdriver) and took off all removable parts. I saw where the handle trigger presses a button (gold on my unit) which was stuck. I cleaned around the button, but it still stuck, so I used a bolt and hammer to hit the button. Good news--the unit now steams. Bad news--it's stuck in the open position and won't stop steaming while plugged in.
  • Anonymous Sep 02, 2008
    heats up but steam wont come out
  • zeejay97 Oct 02, 2008
    i also took mine apart.....hit that brass button with a small hammer and got it to work...........now it steams without me pressing the black button so no control over the steam.......i dont think you can win with this thing!
I posted this in the problem section, but it's also a partial solution:
Posted on Jun 21, 2008
I found that my wife had used tap water which is from a well and that caused a buildup on piston which was stuck closed. I took the handle apart and sprayed some lube on it which freed it up.The piston only travels/opens up about an1/8 to a 1/16th of an inch. Hope this helps.
Posted on Jun 12, 2008
I have been told that you can use a can of WD40 and lubricate the hoses and nozzle.  Try this I hope it works.  I have a Scunci too, but I haven't had this problem yet, I got it almost 2 years ago.
Posted on Oct 12, 2007
I think the inside is clogged
Posted on Sep 26, 2007
RONSHESTACK@AOL.COM
Scunci International
2200 Byberry Road
Hatboro,PA 19040
Google search should provide a lot of options for obtaining the brush's but don't forget EBAY as it has been sometime ago but I had bought brush's for my steamer threw then. Good Luck!
May 25, 2014 | Scunci SS1000 Handheld Steam Cleaner
How do I get a stuck top off a Scunci ss1000 steamer?
try putting it in a freezer for awhile cold makes metal shrink and that may loosen the top .
Dec 07, 2017 | Scunci Ss1000 Steamer Irons/Steamers
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
HEATS UP BUT NO STEAM?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
n
Jul 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Scunci steamer will not heat up
Take the bottom off (Just break it after you get the two normal screws out), find the white wire from the element, bridge the offending fuse located under the special insulation, with a piece of wire, if you cant replace it, re assemble, and steam away. If the lack of that fuse worries you, don't do this, just pitch it.
Jan 13, 2009 | Scunci 52000 Handheld Steam Vacuum
My scunci steam cleaner has a white build up and is clogged. How can i clean it?
I had not used my scunci for a few months and now it is completely clogged. I tried vinegar over night and removed a lot of sediment, but it is still not working. My last shot was going to be to use lime-away. Any suggestions. All parts look in mint condition, but it just doesn't work.
Sep 28, 2008 | Scunci 52067 Handheld Steam Vacuum
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Scunci ss1000 handheld steamer
My Scunci MS 1000 heats and builds up steam, but the steam does not release from the spout when the release button is pushed. Plenty of pressure is built up inside (escapes when cap is opened). What is the problem?
Aug 03, 2008 | Scunci 52001 Handheld Steam Vacuum
Scunci 52067 Handheld Steam Vacuum Logo
318 people viewed this question
Top Scunci Vacuums Experts
Craig Butler
Craig Butler
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
