Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 HP Intek will not start. Engine turns over but will not start. I installed a new sprak plug and new gas line filter. After it sets for a while it will fire once or twice and then nothing. I checked the spark ignition and it is working fine. It seems to be a carb or fuel problem.
  • petie44 May 13, 2009
    Hello
    I have a Kohler 19 HP L2000 that is 3 years old. I put in a New spark plug today and had to recharge the battery. Ran fine last week, but will not start this week. Turns over, but will not start.
    Any ideas?
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
  • 138 Answers
SOURCE: craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Posted on Aug 17, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
bargainbin2
  • 123 Answers
SOURCE: 18.5 Intek OHV Briggs-DLT3000 Craftsman - Won't start - backfires
Check the switch under the seat.
Posted on Oct 03, 2009
backwoodsctr
  • 169 Answers
SOURCE: DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Posted on Nov 30, 2009
I have a Craftsman 23 hp Twin OHV Intek engine garden tractor. It has recently started idling badly, the motor runs up and down up and down. Battery, fuel filter, oil and oil filter, are newly changed,...
Before you get more into that engine I would suggest trying new gas especially if its been sitting for a while. Then I would try running some carb cleaner through it and see if that settles things down. If there is any water in the fuel it can cause those type of issues so try the simple fixes first then if all else fails go to the harder fixes.
Jun 19, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
My craftsman riding lawnmower cranks over strong but will not start
Do you have spark? There are two things to look for when any engine won't start....fuel & spark, Take your plug out and lean it up against the metal of engine...turn it over and see if you see a good blueish spark.
No spark? Could be the plug, safety switch, coil
Next squirt a little gas into spark plug hole, replace the plug...will it fire up? If so...start working your way back down the fuel system....carburetor, fuel lines, fuel filter and gas (is gas old or new? is there any water in it?)
try that...www.nnyparts.com
May 29, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
426 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
