Question about Toastmaster 1148X FastBake Bread Maker
Belt is loose
When the machine is kneading it makes a terrible skipping gear noise.  The bread is fine but the noise is terrible.  We were able to take the belt off but dont know where to find replacement.
  • 3 Answers
The parent company is Applica & apparently these machines were/are manufactured by Black & Decker. Here is the contact information: Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Contact us
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)
Contact us
Website: https://secure.prodregister.com/prodprotect/applica/tm.shtml
Posted on Jan 01, 2010
    Sergeant:
    Champion:
  • 245 Answers
Go to the store where u bought the bread maker and ask them where u can get a replacement belt...if no luck ring the manufacturer and ask them....
Posted on Apr 19, 2009
Toastmastter breadmachine model 1186. I used it two days ago, worked fine. Today the drive belt will not turn. It makes a small clicking noise. Can you oil the shaft or are the bearing gone?
Hi, Take the bread pan out of the machine and see if it still makes the noise when you start a kneading cycle. If it still makes the noise then the belt may be loose or a gear has chipped. If everything is normal then it could be the bread pan. There is a sealed bearing on the bottom of it and when that breaks or freezes then the paddle won't turn and it's time for a new bread pan Be sure to unplug the machine when checking belts. They are located in the base of the machine. Hank
Jan 24, 2011 | Toastmaster 1183N Bread Maker
I hvae a Regal K6726 Bread Machine that a friend gave me. When I went to use it the first time, the Kneading Blade did not turn and the bread did not mix. It made a clicking sound, but did not turn. When I...
Hi...Take the empty pan out of the machine and spin the paddle by hand. It should turn freely with no sticking and should not be loose. There is a sealed bearing on the bottom of the bread pan and if this fails then the paddle will stick and be really loose if you try to move the paddle up and down. . If this is okay then check the belts and gear. They could be loose or worn out. Belts and motor are located in base of machine. Be sure to unplug before checking this out. Also, make sure bread pan is installed in the machine correctly. Hank
Jan 17, 2011 | Regal Ware Kitchen Appliances - Others
I have a toastmaster Bread Box bread machine...I am making French bread...the banging noise was so loud I stopped it fearing the machine was broken...is it ? If not should I continue the kneading/baking...
Unless the sound is mechanical like metal on metal etc. what you may be hearing is the sound of the dough ball being knocked around and kneaded. Sometimes that gets pretty loud. While it is kneading go ahead and open the top and see if you think the dough ball is making the noise. If it seems to be coming from somwhere else then you may have a more serious problem. Is this a new noise or it this the first time you have used the machine?
Nov 08, 2010 | Toastmaster 1183N Bread Maker
The bread machine will not knead m I have made sure it is connected right and even started over with a new batch, it makes the nosie like it is trying to work but will not knead.
Hi, A few things may cause this problem. Make sure the bread pan is inserted correctly in the machine. If ok, then take the bread pan out of the machine and see if you can turn the paddle by hand. It should turn nice and smooth, If it sticks or does not move then the sealed bearing that the paddle spins on has failed. If that's okay then keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning smoothly. If no then the belt is loose, broken, or has fallen off the pulley.. Good luck Hank
Jun 04, 2010 | West Bend 41077 Just For Dinner¿...
Loaf of bread...clumpy mess
Hi...
Yup check those belts. Also make sure the paddle spins freely when you spin it by hand. If the paddle does not spin freely, then the sealed bearing may be going bad. Hank
Apr 11, 2010 | Black & Decker B2300 Bread Machine
Our rarely-used Black and Decker B1650 bread maker has started making a really loud clunking noise when the paddle is kneading the dough ball It does not make the noise when not under load ... I ran the...
It could be the belt is slipping or a loose gear. Take a look at the gear & belt assembly in the base of the machine. Also, make sure the sealed bearing in the bottom of the bread pan is not sticking. It should turn free by hand Hank
Feb 16, 2010 | Kitchen Appliances - Others
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Kneading Blade chattering
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Jan 02, 2009 | Sunbeam 5891 Bread Maker
Toastmaster 1148X FastBake Bread Maker Logo
211 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
