Question about Midisoft Play Piano 2.0 Full Version for PC
Two computers using single port modem and second gets timed out
I've got my main computer set up with the standard 2wire 2071-A modem and that's working fine. However my bro just got a laptop and set up the modem to his laptop. The internet usually works fine for about 10 minutes or so then it locks out on his computer and I have to restart the modem and we get another 10 minutes. Is there some setting I can't find on the modem?
I don't want both computers running at once on the internet because I just disconnect mine from the modem and put his in, but it usually gets locked out after a while. Any help?
His laptop is a COMPAQ Presario CQ60 if that is any help at all.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
It may need permission. If it's anything like the modern ones, it should have a web address, something like ( http://192.168.1.1 )
if it does then you have to log on and give the devices mac address permission to log on. Or it should be something simular to this.
Posted on Apr 07, 2017
sriramoju
  • 171 Answers
SOURCE: 2wire moden
check the modem diagnostics it is ok try to reinstalling the modem drivers and create a new dail-up connection
Posted on Mar 24, 2008
SOURCE: no wireless connection
Child got into the wires behind computer and disconnected the wireless and I no longer have the directions can you help me?
Posted on Jan 16, 2009
SOURCE: how do i reprogram a
First, get the modem/router's setup and user manual from http://www.2Wire.com/pages/driversanddocumentationsupport.php?did=6
After studying those, read the instructions at
http://support.2Wire.com/index.php?page=view&article=21
After having done your homework, do the following:
1.) Port Configuration
BitTorrent clients listen (wait for) incoming connections on one of the 65535 ports of a PC, the listening port. The typical port range for the BitTorrent protocol is 6881 - 6999, which means that you should choose a port from this range as the listening port, because many other people configure their firewalls to only accept incoming connections on these ports and might consider exotic values as suspicious. Yes, many ISPs throttle the throughput for file sharing applications, but if they are serious about hindering P2P activities, there are many more sophisticated ways to identify BTs, for instance by means of analyzing traffic, packets, connection and usage statistics, etc., instead of relying on the port number only. Consequently, as long as your ISP does not interfere too much with your file sharing and/or if changing a non-standard port doesn't remedy the problems, stick with the standard port range of 6881 - 6999.
If you do choose a different value, make sure that it isn't the standard port for other Internet activities (FTP, HTTP, SMTP, etc) or even worse, known as the port used by some malware. As a rule of thumb, steer clear of the lower numbers and rather choose a higher number, because the lower ranges are often occupied by other applications. In case you are using a hardware firewall (router) and/or a software firewall, do not activate the 'randomize Ports' function but stick with the same port all the time.
In Opera, the best of all web browsers that comes equipped with an internal BitTorrent client, you can find/modify the port number by entering 'about:config' into the address bar and expanding the BitTorrent section.
2.) Software Firewall Settings
People using the MS Windows XP/Vista firewall go to Options -> Preferences -> Connection and check 'Add µTorrent to Windows Firewall'. People using other firewalls will need to refer to the respective software's documentation.
You will have to allow incoming TCP connections on the port that you chose as the listening port in your BitTorrent software. BitTorrent does not use UDP, so creating a rule for TCP only should do fine.
3.) Router Username and Password
In case your PC is protected by (connecting to the Internet through) a router, a few additional steps need to be taken in order to enable software to establish outgoing connections. Some people who do not have a separate router may find that their modem serves both as a modem and as a router, and this procedure will also apply. This is the case  with the 2Wire HomePortal Gateway 2071.
In your web browser, enter http://192.168.1.254 as the address (study the manual or your old notes for a different address) and have your username and password for the Gateway ready. If you can't find them and were given the modem by your ISP, you will have to call them because if you only change the password on your end, you won't be able to connect to the Internet any more. In case you need to change the password,  see the user manual for the respective hints.
4.) Router Firewall Configuration
Enter the Gateway 2071's address in your web browser's address bar, go to Firewall -> Firewall Setings and select the computer for which you want to enable port mapping.  Since 2Wire Gateways offer a maximum of four LAN ports, identifying which of the four computers is the one in question shouldn't be too hard a task.
Now click on the 'Add a new user-defined application' link  beneath the list of pre-defined applications. Define an Application name like "BitTorrent Client" and enter the listening port into both port range fields, for instance from 6885 to 6885 for the TCP protocol. For BitTorrent, everything else can remain blank/none and you click on 'Add Definition'.
The page reloads and after you went 'back', select the freshly added profile from the list of applications and click on 'Add', then on 'Done'.
It's not really that difficult, but router manufacturers somehow always **** at describing the steps properly because they never provide examples for the three typical 'problem cases' online gaming, VoIP and file sharing. Three examples in each category and millions of users wouldn't have to hunt the Internet for clues.
Good luck,
KARSTEN KEESE
Posted on Mar 25, 2009
falter
  • 245 Answers
SOURCE: 2wire modem keeps on disconnecting
looks ur internet setting is not right on ur new laptop for the modem u are using....call ur internet provider and ask them for technical advise and help
Posted on Apr 19, 2009
c_robertson
  • 123 Answers
SOURCE: I need manual installation instructions (dont have
It appears to be a DSL modem. You don't need a driver, but a username and password for your internet provider. Here is how you install.
connect to phone line then usb or network port (drivers should be built in xp) open your internet browser and type 192.168.1.1 to open the internal web page. It should step you through the username (email address) password. Must ask your internet provider for those.
Posted on Apr 29, 2009
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
Please tell me is my internet modem 2wire 2071 A wireless, can I connect a laptop with it
Yes you can provided you laptop has a wireless card and it is configured with the router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 30, 2010 | 2wire (1000-000057-000) Modem
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
Please excuse my very limited knowledge of wireless connectivity! I currently have Juno DSL, with a 2wire modem (2071 - no wifi) and I want to add wifi capabilities to my house. I assume that I need a...
As I understand it, you currently have a DSL line with a computer plugged into a modem that is attached to the DSL. Now, you want to use wireless throughout your home.
My choice of router manufacturer is Linksys though there are other manufacturers of wireless technology.
What ever manufacturer you choose, get the device. Hook it up according to the instructions you will find inside the device box.
It will go something like this: Attach a cat 5 cable from the "uplink" port on your router to the DSL modem. Plug your wired computer into any of the 4 other ports. Everything is off, right? Cycle the modem - wait for the lights to settle down. Plug in your new wireless, wait for the lights to settle. Turn on your computer. Turn on your wireless. Wou may have to connect using the windows wizard.
A tool I use for network management is Network Magic, a Cisco product. Cisco also owns LlinkSys.
Get the program, free download and eval period. After the eval period you may purchase or continue to use the product with some features disabled.
http://www.purenetworks.com/download/
Thanks for posting your question at FixYa.com
Please vote
thanks
a
Nov 13, 2009 | Computers & Internet
I got d-link dir-615 wireless router and a 2wire modem 2071-a and when i set up the d-link router my desctop computer that is pluged into d-link cant get internet im 11 and got no idea wat to do oh and the...
does the computer that's directly connected to the modem connect to the internet? If not then make sure your settings are well set, your service provider (ISP) and all the other settings that your ISP supplied you have not been tempered with or modified.
Does you WDS and router communicate? Have you changed the IP addresses form the default ones that came with your devices? They usually begin with 192.. at times the default IP addresses don't work in some institutions. You can configure most DLinks using internet explorer by typing in the DLink IP address bar.
Considering your age, you need someone to show you how these things are done.
Aug 24, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
I have a 2wire 2071 - A modem and it wont read my ethernet cable
First check device manager to see if the copmuter recognizes the card, if it dont use the add hareware app, and have windows plug &play try to locate it. then open the case and remove the card with windows running and replace it in the slot , P&P may then locate it if windows doesnt, then the ethernet card may of had a voltage spike go thru it and fried the card.
Jul 12, 2009 | Computers & Internet
Apr 19, 2009 | HP Compaq Presario CQ60Z Notebook
Configure D-Link Wireless N Router DIR-615 for 2wire 2071-A modem
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
login ADMIN and pass is blamk
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Apr 04, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
How do i reprogram a 2wire 2071-A
Do you have your instructions? I can tell you but it would be easier for you if you can just look at the guide and take your time. You can do a reset and then reprogram. If that's all you want to know I can do that. Would you want me to get you athe manual or tell you specifically how to do something?
May 03, 2008 | Computers & Internet
2WIRE Single Port DSL Line Filter
i think when you purchased the 2wire modem it usually comes along with 3 sets of single port dsl line filters, try out those other filters see which one works. if the local network light doesn't come on, (are you using 2wire 1000 series?), check the network adapters in your computer, this usually happens when you are using lower versions of OS. try the power outlet in the kitchen / bathroom, if power light doesn't come on, push the reset button for 30 secs. if power light is still off or red, then you may need to replace the modem (check if it's still under warranty, if not you will need to buy a new one.) also you should be using the same power adapter that came with the modem, check the specs. sometimes if the modem is more or less than 3 years old, they could get defective especially if it's often affected by sudden power surges.
Jan 29, 2008 | 2wire Single Port DSL Line Filter (21869)
Midisoft Play Piano 2.0 Full Version for PC Logo
117 people viewed this question
Top Midisoft Computers & Internet Experts
David Payne
David Payne
Are you a Midisoft Computer and Internet Expert? Answer questions, earn points and help others
