Question about Dishwashers
Kenmore dishwasher will not drain
The dishwasher will not drain properly or at all. the inside bottom is full of water please help!
    Sergeant:
    Champion:
  • 245 Answers
Check ur valve and clean it out possible blocked read ur Manuel for dishwasher and help tips
Posted on Apr 19, 2009
What would cause the inside of dishwasher to slowly fill with water even in off position.the water drains just fine, but after drained it will slowly start filling the bottom of dishwasher back up.
the water control solenoid unit has a faulty diaphragm in it allowing water to pass even though the power is off
replace it or turn the tap off after each use
call a technician for the proper diagnosis and repair
Jan 28, 2017 | Dishwashers
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
My dishwasher wont drain! help
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter located inside the front bottom access panel for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore 16769 Dishwasher
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
My Kenmore dishwasher leaves water in the bottom of the dishwasher. Is that OK? I notice the water when I clean out the bottom tray.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 18, 2011 | Kenmore Washing Machines
Not draining properly
Check for plugged drain hoses in your dishwasher, also make sure that the pump is working correctly
May 06, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher M# 665 s#16632000 STOCK# FL4313714 It is leaving about 2in. of water in the bottom once its done with the wash cycle. When I push the drain /cancel button and take drain hose off the...
I would remove the bottom panel of the dishwasher and remove the drain hose from the pump. On some of the Kenmore Dishwashers you can remove the drain spout where the drain hose attaches to and clean. Sometimes something will catch inside the drain spout.
I hope this helps.
Feb 03, 2010 | Dishwashers
Kenmore dishwasher (model 655) not draining
when i attend dishwashers that have lost power to some part, i always check for broken wires inside the door skin, the wire harness inside the door skin gets hot and cracks with use when opening the door all the time after that check the outlet pump which is often a separate part to the main motor, this pump could be faulty electrically
Sep 27, 2007 | Dishwashers
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
