Question about Car Audio & Video
How to remove stock radio to install direct connect for sirius radio.
Need to remove stock radio from a 2006 ford taurus to install direct connect for sirius radio. How do I remove the stocl radio?
    Problem Solver:
  • 13 Answers
There should be two sets of holes on the sides of the radio that have two holes each. You will need a tool call a ford radio removal tool that you can get at any auto parts store for about 5 bucks. When you get that stick both of them in those holes and push them outward to push the retaining clips in and then pull (with the removal tool) the radio out. Sometimes these radios come right out and sometimes the retaining clips like to be a pain but just stick with it and it will come out.
Posted on Apr 23, 2009
Removed my battery in my ford escape 2007 when i put the battery back the radio is asking for a code help please
It most likely that your radio has a Sirius account and it is looking for its #ESN number
The following link shows how to access the number in the Ford section of the page
Find Your Sirius Radio ID SiriusXM Radio
I hope this has been a help?
Jan 10, 2016 | 2006 Ford Escape
HOW DO I TAKE APART THE DASHBOARD ON MY 2006 FORD F150 TRUCK? I WANT TO INSTALL SIRIUS RADIO
If its like my ford ranger the dash is held together with small medal clips . start at the corner of the dash on the driver side and carefully pull the dash piece towards you. i've taken mine apart 3 times now and i find that the medal clips needed to be reshaped the third around make sure your vehicle is nice and warm or you will crack the plastic
Feb 13, 2010 | Sirius Satellite Radio Receiver
I have a Sirius Stiletto 2 radio. How do I
NO there is no line input jack the AUX button was made for the rear video system
but there is a audio adapter you can use go here
to read more about it
FRD04-AUX
Dec 28, 2009 | 2006 Ford F-250 Super Duty
Sportster 4
Shouldn't need one. Does the rear antenna connect to the direct FM box?
Aug 30, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Radio Antenna Adapter for Sirius radio add-on
Brought problem to my trusted auto mechanic and he found a simple disconnect/connect where to antenna cable comes into car under front right side under the glove box. It took literally 30 seconds to do.
Jun 18, 2008 | 2005 Mitsubishi Endeavor
I need to know how to remove the stock radio from a 2003 ford taurus so i can install an ipod adaptor
Ebay has the tool for removal cost $1 plus shipping. this tool is for the 2 holes on left and right side of radio face fit tool in then push alittle out worad and pull. Follow aftermarket instructon on install.
Jun 15, 2008 | 2003 Ford Taurus
Car Audio & Video Logo
202 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
