Question about Nintendo NES Console
Nes Nintendo Channel Trouble
Yesterday I received my nes nintendo off ebay. I plugged everything up correctly and was ready to turn on the tv and play with my old school nintendo. Problem, I was unable to figure out how to get my channel 3 or 4 to show the game. I have a fairly new tv with directv. I tried switching off the satellite and changing the channels, but couldn?t figure out how to get the tv to show the game. The power button on the nintendo showed that it did have power. Anyone have suggestions?
    Problem Solver:
  • 14 Answers
Are you using a/v (audio/video cables with rca ends), or direct to cable input on t v.? if direct to t v, did you check ch switch on back of system deck? otherwise is t v programmed for the correct INPUT. T V, AV1. AV2. OR AV3? ANOTHER PROBLEM WITH OLD NES IS YOU MUST CLEAN THE GAME EVERYTIME YOU INSERT IT. TO CLEAN MIX ALCOHOL/WATER 1-1 AND USE QTIP. RUN IT UP AND DOWN BOTH SIDES OF CONTACTS. IT WILL DRY RIGHTAWAY.
Posted on Sep 20, 2007
  • RICHARD SANFORD
    RICHARD SANFORD Sep 20, 2007
    IF IT WORKS, BUT BLINKS, AGAIN IT NEEDS CLEANING. THERE IS ALSO A CLEANER THAT GOES TO CLEAN INSIDE CONTACTS. WHEN ALL THAT FAILS, YOU MAY NEED NEW CONTACT PINS INSTALLED.
SOURCE:
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nov 25, 2011 | Nintendo Super NES Console
I just tried to try my NES (wichs hadn't been use for a long time) again. When i plugged everything and turned the NES on, the light start blinking. Then, I put a game in it and opened the tv on channel 3....
You can try to change the input to Video instead of channel 3 since you're using a RCA (Red, Yellow and White) cable.
Thanks for using Fixya.
Jan 31, 2011 | Nintendo NES Console
How do i get my nintendo nes to work through a bush freeview lcd flat sreen tv i have connected it up correctly
Use the RCA AVI outlets on the side of the NES and not the RFI (cable) outlet on the rear of the unit. Tune your TV to the appropriate Video Input channel.
If still no signal, try another set of AVI cables.
Try the console on another television.
If no output from the NES, then it will require refurbishment. Click here for more information.
Please let me know how I may assist further.
Apr 21, 2010 | Nintendo Super NES Console
I cant tune in my nintendo do you know what its meant to be set too
Hi your NES should have on it's right hand side 2 Audio Video inputs have you tried connecting it to your TV via Audeo Video Cable and selecting Video channel on your TV dont worry about using the old RF switch they are for older TV Units. Here is a picture of what the AV Cables look like http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/nintendo-nes-audio-video-cable-no-more-tuning.html
Jan 16, 2010 | Nintendo NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
Super nes
Super Nintendo doesn't work with new TV's.
Jun 26, 2008 | Nintendo Super NES Console
Nes nintendo
channel 3 is the correct channel. Blow the dust out of the cardridge and console and see if it works.
Feb 17, 2008 | Nintendo NES Console
Problem with NES
Check on the back of the nintendo system if it is on same channel as tv, little switch is on the back next to the power cord.
example..tv channel 3 and nintendo system channel 3
If that doesn't work your cable is not properly connected, You can't use both rf switch and av cable. It one or the other. rf connect in the back and to coax cable. Av cable connect on the right side of the system and front input on tv..
Make sure your games are clean also. Good Luck.
Sep 17, 2007 | Nintendo NES Console
Nintendo NES Console Logo
135 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
