Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not agitate or spin
When you start a cycle the washer just hums. you cannot turn the agitator by hand when the washer is not running. the water does drain out before the washer quit running there was a tingling noise underneath the washer.
    Sergeant:
    Champion:
  • 245 Answers
It looks to me u need a new motor as the one u have is burned out...this is the humming u hear....contents insurance will pay for new motor if u have one
Posted on Apr 19, 2009
A ge top load washer first began by making a buzzing noise instead of spinning. Now it doesn't spin as fast as before or just wont spin. Jeans wrapped around the agitator shouldn't damage the spin?
the agitator spins with the tub so clothes wrapped around the agitator will have no effect on the spin other than a balance problem
The hum and failure to start spinning may be attributed to a failed (failing ) start run capacitor or program board not moving on properly
As the start /run capacitor is for the motor and if it start the wash cycle ok but after that cycle ( around 30-40 minutes) it may be too hot to restart the motor for the spin
I suggest that a technician be called in to get a proper diagnosis and a quote
Apr 14, 2016 | GE Washing Machines
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Kenmore 70 series washer making humming sound and won't agitate
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2009 | Kenmore Washing Machines
Kenmore Washer No Spin >> Motor problem
It's probably the motor coupling. Same thing is happening to me, but I can not gain access to the motor
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Nov 27, 2006 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
221 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
