Question about GE WSXH208A Front Load Washer
Packing support bars
I purchased my washer in May of '05. I moved in Aug. '05 to a new location. My brother-in-law put in the barrel support bars that are necessary for transporting the washing machine. The local appliance repair co I called in to remove the bars and hook up the washer & dryer forgot to remove the bars. One load was run (started & left the house)& upon the second load it was obvious by the terrible banging the support bars had not been removed. When the appliance man came out to remove them I asked what type of damage was done to the machine. He said none which I questioned. On and off the clothes seemed to be more wet than they should have been. 8mo later the pump went & now the barrel is all over banging the inside of the machine. Does anyone know wether or not the support bars being left in could have done damage to the inside of the machine causing or leading to the trouble I've since been having?
  • 249 Answers
Without a doubt .YES
Posted on Nov 25, 2007
When do Flybe fly to Verona Italy from Southampton
Flybe Timetable
BE1223 07:35 10:55 . . W . . . . - - 16-Aug-17 - 30-Aug-17 BE1223 10:00 13:15 . . W . . . . - - 06-Sep-17 - 27-Sep-17 BE1225 10:05 13:25 . . . . . Sa . - - 02-Sep-17 - 23-Sep-17 BE1223 10:05 13:25 . . W . . Sa . - - 12-May-18 - 16-Jun-18 BE1225 10:10 13:30 . . . . . Sa . - - 19-Aug-17 - 26-Aug-17 BE1223 15:25 18:45 . . . . . Sa . - - 19-Aug-17 - 16-Sep-17 BE1225 15:25 18:45 . . . . . Sa . - - 12-May-18 - 16-Jun-18
Sep 13, 2017 | Cars & Trucks
I need a magnetron for a Brother MF3200 microwave oven
How did you get on with your search for a new Magnetron ??
I have one of these great little cookers, but the buttons on the control panel are "sticking" or only intermittently operating - have to press pause many times to get the machine to shut down. I might need a new control panel or at best the one fitted needs a good internal clean - have you stripped your mmachine down ??
Jun 21, 2012 | Microwave Ovens
Locked in park
I am guessing here but if it is the same as my brother in laws car there is a safety lock on the gear shift under the console, my brother in laws car locked in park and it was impossible to move the gear shift out of park.
The safety lock was the problem, I could not see why they put it there as the shifter locked into a groove anyway so I removed the lock and he has had no trouble since
Jun 12, 2010 | 2006 Saturn ION
Whirpool Duet Washing machine F-11 error
I purchased a Whirpool duel washing machine Aug 05. In June of 08 it showed an F11 error. After factory repair service tech. looked at it he said that i needed a main motor at a cost of $400.00 After search on internet many people reported problems also and decided not to repair it. Has any one had problems with theirs?Ihave the same problem is there any solution????please help
Jan 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer was moved from one location to another; when turned on at new location it makes a noise and code of DR
Many washers have a sipping rod or bar that needs to be inserted into the unit from the rear or the bottom; this keeps the drum and balance mechanism stable while being moved. Either, the bar/rod is still in the unit and causing the noise, or it was never inserted for the move and the drum balance is off kilter and need to be physically repositioned so the drum sits well centered. Most likely, nothing is broken; just a nuisance. Goodluck, Macgivor
Dec 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Car shakes every time when appling brakes
The rotors are warped, need to replace them, also when the wheeles are put back on, the lug nuts need to be tourqued down to the specifications for that car, or the new rotors will warp again.
Jun 19, 2009 | 2005 Chevrolet Equinox
Need bolts to stabilize washer for move
Dont know if you can purchase these. First people to try are the manufactures. Otherwise, unscrew the two screws at the rear top of machine and pull backwards to remove top.Then pack some towells or rugs around the drum then replace top. Don,t forget to remove rugs at new home.!! Good luck on your move.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
61 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
