Question about Crown CE2000 2-Channel Amplifier
I own a ce2000a amp channel 2 ouits after about 45 mins of playing time. a tech said that he fixed the problem the amp on chnnel 2 side keeks cutting off. please help me with this problem.
CANNOT DUB FROM VHS TO DVD. IT RECORDS A SNOWY PICTURE AND NOT WHAT'S ON THE VHS.
you've got the record chnnel set wrong,play a VHS see what chnnel it plays on then set that channel as your record channel, or find a sync button on the unit or remote.
Nov 23, 2010 | Toshiba D-VR4 DVD Recorder/VCR
My roof air blew the 20 amp breaker eleven times over the weekend.we were in the sun and had 95' air temps.
You are making near impossible demands from your roof air ... cut down the expectation a little bit ... let your AC try to keek up.
Jul 15, 2010 | Dometic Rooftop RV Air Conditioner
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
Aug 26, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Crown com-tech 2 channel 400
One channel has failed and is in need of repair. There are some transistors inside that are "noisy" and sending signals down the line. This is a bit tricky to find, but a service shop that does audio repairs should be able to fix this. Figure about $15-$45 for parts depending upon what circuits are effected.
Dan
Aug 29, 2008 | Audio Players & Recorders
Channel cut out
Stereo Tech: Sounds like you definitly have a broken solder connection on the main PC board. A bad solder connection is tricky to find somtimes if one is not familiar with exactly what it looks like (kinda like mt st helens with a ring around the top) if you attempt this yourself DO NOT MAKE A SOLDER BRIDGE you will open pandoras box. Good luck
Jan 08, 2008 | Sony STR-DE697 Receiver
Technics SU-V460 Amp Problems
Hi There, you need to eliminate all the connection and surplus items around the SUV-460 amplifier to determine if its the amp or not..
That is disconnect every thing then connect just the speakers and an input to the amp like a CD player or radio input. Then see if the amplifier plays OK thru the speakers on both channels and the balance control works fine....If it doesnt then the fault is inside the SUV-460 but if it all works fine than start reconnecting theemixer panel carefully and recheck all your cables and connections. Its a process of elimination to determine if its a "Box" fault or a cable fault...
Cheers From YUBEUT
Nov 14, 2007 | Technics SUV500 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
94 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
