I'm currently having problems with my Orbicam, the little light does not come on and anytime I try to click on the icon on the desktop my PC shuts down. The notebook is not even a year old, but I know that there are frequent updates when I shut down sometimes. Can you help please?
To answer this question i have to ask a few first. Do you know what operating system that your oribcam requires ? and what os are you running on your aspire ? If you can answer these questions for me I am more than willing to follow up on this for you. I will give you specific details on how to fix this problem. When you comment please include your ram or memory size and speed. Plus i will need to know the processor that you are using.
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
cut my labtop on it runs checking files cc: FILE SYSTEM FAT 32 And i can hint esc and f12 it says...
(More)
cut my labtop on it runs checking files cc: FILE SYSTEM FAT 32 And i can hint esc and f12 it says system disable code comes up 030371 ,yes it says disks to be checked for consistency . you may cancel the disk check ,but dont need to windows is checking the disk volume #1f10-d7ad , hdaudiuo soft data fax modem with smartchip txt is cross-linked on allocation unit 1769593. cross link resolved by coping. convert lost chains to files ,yes . windows has made corrections to the file system they are alot kb in alot of these files unbeliveable . in files and foleders . when i went to get my labtop it was on ablack screen it said some of files was not downlosded right i didnt get to read it all i pick it up it come back to this screen
acer aspire 5100-3583 "black screen" after changing the ink cartridge on the attached...
(More)
acer aspire 5100-3583 "black screen" after changing the ink cartridge on the attached printer. The computer seems to boot/be on, but the screen remains totally black.
acer laptop aspire 5100, keyboard,all 3 USB ports, touchpad all inoperative.Unit booted up normally...
(More)
acer laptop aspire 5100, keyboard,all 3 USB ports, touchpad all inoperative.Unit booted up normally and screen OK.
My wireless connection worked fine up until today...I have reset the switch on the front of my Acer...
(More)
My wireless connection worked fine up until today...I have reset the switch on the front of my Acer Aspire 5110 and it continues to be ''orange'' rather than ''green'' that would indicate is on and working properly When trying to re-set up a wireless connection, I continue to get an error message telling me that the cable is unplugged? We are on a LAN, using a router, I have a connection just fine on my desktop, which is what I am on.
Compaq laptop: my mouse pointer or arrow is frozen. It happened when I was using email. On the...
(More)
Compaq laptop: my mouse pointer or arrow is frozen. It happened when I was using email. On the scroll bars of the email, at the end of the message, two transparent boxes appeared, similar to those when setting margins on Word. Have I locked the mouse pointer or is there a fault? The mouse pointer sometimes works when the screen is setting up, but soon freezes. Your solution may need to include how to solve the problem with the keyboard only, because, of course, I can't use the mouse pointer to click. I have tried going to the computer settings and accessing the mouse dialogue box, but have limited use with the arrow keys and the enter key.
