Question about Apple iPhone 3G
Cannot pair iphone with Samsung WEP350 bluetooth headset
The iphone reconizes the samsung wep350 bluetooth headset but will not pair. I push the device name on the iphone and it just spins.
SOURCE: pairing headset
you need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Posted on Nov 22, 2007
  • 94 Answers
SOURCE: Iphone does not pair with LG HBS-250 Bluetooth Headset
the bluetooth of iphone is not compatible with this.get the bluetooth application installed from itunes store to maki it compatible.
Posted on Dec 04, 2009
SOURCE: My Jawbone headset will not pair with the iphone
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
Posted on Mar 29, 2010
  • 49 Answers
SOURCE: My iPhone wont recognize my Z9 Bluetooth (blueant) headset
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Posted on Apr 09, 2010
  • 25 Answers
SOURCE: iPhone 3G bluetooth problem
sony not so good.. try this will work best for your iphone.
Posted on Apr 25, 2010
When I try to connect my handset WEP350 with my mobile he ask me PINCODE but I don''t remember it? What can I do?
most blue tooth manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 18, 2011 | Samsung Ultra-Slim WEP350 Bluetooth...
My ps3 found my samsung wep350 and says it is connected but when I try to use it while playing, I get nothing. Any suggestions?
did you try: Going to ps3 main menu go to settings tab in the settings tab go to: accessory settings make sure your correct bluetooth is active then go audio device settings (still in accessory settings)
make the output and input to the correct bluetooth device and press ok... try that
Jan 09, 2011 | Samsung Ultra-Slim WEP350 Bluetooth...
I am using samsung bluetooth wep350 which was paired to my old i phone .now i have changed to i phone 4 .....i am unable reset the bluetooth wep350 to my new phone ....plz guide plz send to...
This headset should be in pairing mode, prior to trying to pair it with another device. The pairing mode in this headset is indicated by its light steadily lit. Starting with it turned off, if it has never been paired before, just by turning it on, it should enter the pairing mode automatically. Otherwise, press and hold the Multi-Function Button for a longer time than the time required to turn it on, until the indicator light is steadily lit. Only then, make your phone's bluetooth application search for new devices. After a little while, the WEP350 should appear on the phone' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further. Regards, Carlos
Jan 02, 2011 | Samsung Ultra-Slim WEP350 Bluetooth...
I don't know how to get the Bluetooth into pairing mode
The pairing mode in this headset is indicated by its light steadily light. Starting with it turned off, if it has never been paired before, just by turning it on, it should enter the pairing mode automatically. Otherwise, press and hold the Multi-Function Button for a longer time than the time required to turnit on, until the indicator light is steadily lit. Only then, make your phone's bluetooth application search for new devices. After a little while, the WEP350 should appear on the phone' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Plase, let me know if I can help you any further. Regards, Carslo
Nov 17, 2010 | Samsung Ultra-Slim WEP350 Bluetooth...
Where would i find a passcode for my samsung web 350 bluetooth
Hi Moralesdee52,
The passcode for this headset is usually 0000 (Four zero's)
If you no longer have the manual you can have a look at the quick start guide for your device here:
Samsung WEP350 Quick Start Guide
This is a PDF file and normally opens on its own as the webpage.
I hope this helps.
Kind Regards
Mike
Nov 09, 2010 | Samsung WEP350 Bluetooth Headset Red
I need help now
What is the problem you're experiencing? What is the phone you're trying to pair the headset with?
Oct 17, 2010 | Samsung WEP350 Bluetooth Headset Red
I want the passcode for sumsung wep350
Have you tried the default 0000 or 1111?
Stelios.
Feb 22, 2010 | Samsung WEP350 Bluetooth Headset Red
Have a samsung finesse and i need help paring my bluetooth samsung WEP350 can you please help me with this issue
1- First turn on Bluetooth function on the Finesse.
2- Then start the pairing mode on the headset (for a Jawbone, make sure it is turned off then press the Noise Shield button for 3 seconds, the LED will begin to flash Red then White.
3- Back on your Finesse you should have the Bluetooth screen up with the search button in center, Press the Search button.
*the search & pairing process takes a minute or two, wait untill your headset finishes and stops blinking.
4- You should now show your Bluetooth device on your Finesse screen.
5- Now with your finger, Press,Hold and Drag the newly found headset icon onto the Search button in the center of screen.
6- A new screen will pop up then asking for the Passcode, enter: 0000 and press OK.
Your New Bluetooth Headset should now be linked to your Finesse. : )
Oct 23, 2009 | Samsung WEP350 Bluetooth Headset Red
Reset wep350
there is a small reset hole on back
Oct 13, 2009 | Samsung Ultra-Slim WEP350 Bluetooth...
Apple iPhone 3G Logo
1,196 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
