Question about Dell Latitude D600 Notebook
Dell Laptop Timer
I was not aware that Dell Laptops have an internal timer. How is that accessed and changed?
  • 6 more comments
  • a1968ryan Apr 19, 2009
    My daughters computer freezes up after 45 minutes of use. It was suggested that her computer may be on some type of internal timer that is shutting it down. I was not aware of such a timer and was seeking further advice.
    She has a Dell Lattitude 600, works fine, freezes up at about the 45 minute time, she pulls the battery and it resets.
    Any advice?
    XP operating
    Now, she is doing a scan using AVG free to check for viruses.
    She uses Macafee, but is checking using AVG. I will see about checking with Microsoft but fear a hardware problem. I am still seeking further advice from this website.
  • a1968ryan Apr 20, 2009
    Removing the battery and re-installing does end the freeze, but what is the answer to this problem?
  • Roberta Smith
    Roberta Smith May 11, 2010
    you may wish to install and run a program called spybot s & d
  • Roberta Smith
    i'd suggest that you are getting bad advice.... is she able to update the computer thru the microsoft website ?
  • Roberta Smith
    what operating system ?
  • Roberta Smith
    what are you trying to accomplish ?
    Guru:
  • 832 Answers
Hi thanks for using fixya!
Please refer to this website:
PLEASE CLICK HERE
Thanks! if you need further assistance, let me know.
Posted on Apr 19, 2009
  • Dennis Jambalos
    Dennis Jambalos Apr 19, 2009
    Perhaps, the problem is with your battery. Try to remove the battery and install it back again.
  • Dennis Jambalos
    Dennis Jambalos Apr 20, 2009
    so it solve your problem by removing and installing back the battery.. because the battery has internal timer that makes your internal memory ticks.
Does th lamp have to be on when programming the timer?
Lamp must be on AFTER timer is programmed and when you plug lamp into timer.
The timer does not 'reach up and turn on the lamp switch' or change between high-medium-low settings on 3-way bulb.
The timer just turns power on... so lamp must be turned on for timer to operate.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Keep in mind that after a programmable-timer's internal battery is charged for 1 hour, you can unplug timer and hold in hand to set ptograms... THEN plug lamp into timer and plug timer back into outlet
Gene
Water Heater Timers Save Money
Mar 13, 2015 | Hardware & Accessories
Can i install wireless card ddapter on dell inspiron b1300? Do I need drivers or softare?
From what I can see that laptop should already come with a dell 1470 A/B/G card internal. It is a mini-PCI card.
This card should work, but be aware it is not an "easy swap" where you would just slide one out and the broadcom in. On most laptops you would have to dissasemble a lot of the components in order to get into the area where the wifi card is held. I have done it on several laptops, but it is not at all an easy task for someone that is not used to building computers.
If it is of any help to you, I found this review that has a lot of info about the specs and such on your laptop.
Mar 01, 2011 | Broadcom BCM94306MP - IEEE 802.11b/g...
Is this timer battery operated, does it need to get the battery changed or recharged. thanks
You posted under Westinghouse 3-outlet timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
If this is not your timer, then add a comment.
The Westinghouse has internal rechargeable battery.
Plug timer in for 1 hour to charge battery.
This is not a replaceable battery.
Other brands of same timer might be different.
I have the Utilitec version of this timer and it has internal battery also.
Jan 10, 2011 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
The instructions say the TimerMax Digislim needs to be charged. No instructions for that. Also I pulled out the little battery protector and it still doesn't work. If all the plastic didn't come out how...
You posted under a photo that looks like the Utilitec 0144506
See image of timer and timer manual on following link.
If this is not your timer. add a comment
Batteries for most plug-in timers are internal rechargeable batteries.
They are not replaceable and cannot be accessed.
To charge the battery: plug timer into receptacle for an hour.
Afterward, unplug timer to set timer program
Next, plug lamp into timer, and then plug timer into wall.
Be sure that lamp is turned ON.
If battery does not charge, then display doesn't show. That means timer is busted.
About 6-8 of new timers are defective from the start.
If battery won't charge, then return timer for another one.
Most of these timers work for a season or two, and then you buy another.
Dec 16, 2010 | Stanley 38424 TimerMax Digislim Daily...
Internal timer on Husqvarna Diamond
Sorry, this is information only provided to certified husqvarna viking service technicians. You can see the sewing hours in the user interface by going to the 'tools/set" menu.
Nov 05, 2009 | Husqvarna Designer I
Malibu 600 watt transformer timer not working. Can turn on and off w/ the switch but the timer isn't functioning.
The timer motor is probably bad. Unfortunately, Malibu transformers have very few user servicable parts :-( , and the timer motor isn't one of them. One cannot even access the internal connections. If you recently purchased the transformer, return it to the store. If the transformer is less than 5 years old, it's still under warranty. In that case visit the Malibu website for instuctions.
Oct 31, 2009 | Malibu Intermatic Inc. ML121RT Low...
Laptop Screen Shuts Down after 45 minutes of use
i think you set the timer on your laptop make sure you dont have the timer on.
Apr 19, 2009 | Dell Latitude D600 Notebook
Replacing timer unit
if like other belling, take side panels off. take off screws holding hobtop and move it backwards. clock should be then accessible
Mar 29, 2007 | Belling XOU492 Electric Double Oven
Dell Latitude D600 Notebook Logo
153 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
