Question about Whirlpool GHW9150 Front Load Washer
Won't drain properly after trying all troubleshooting options
My whirlpool GHW9150PW0 won't drain properly and gives me a F02 error. I disconnect drain hose washed it out. Cleaned drain ABS pipe from washer to main drain. ran wash cycle on hot water 3 times. and I still get error.
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Whirlpool washer ghw9150pw0, error message f02. I have removed, cleaned and checked all drain lines and checked backflow ball. everything is good. May I assume the pump is bad.
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
The f02 error code is a long drain error meaning the following and here is what needs to be checked before replacing the pump
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 06, 2011 | Washing Machines
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Stops cycle reads suds or F2
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. "Sud" code flashes 4 minutes after the pump is turned on and 4 minutes later "F02" flashes. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model # GHW9400PL2 solution for the FO2 error indicator
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F02 appearing. Not fully draining.
Oct 26, 2010 | Kenmore 44832 Front Load Washer
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front loader model ghw9150pw0. it is flashing F02 and not draining. I took front off anf cleaned out screen full of lint put still does the same thing. Drain hose in back is not kinked
buy a bottle of Roto Rooter in the black bottle pour the whole 1/4 of it in the machine let sit for 1 day. Run the whitest whites cycle. If same thing, repeat, it fixed mine.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model ghw9150pw0 has an error message of f2. The washer does not go thru the cycle and now the door won't open. Help whats wrong
or
or
This error code indicates that drain times are longer than it should be
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose from on the drain hose, and secure the drain hose.
The most common cause of a slow drain is the drain pump screen is clogged with lint. Unplug the washer and remove the bottom front panel with 3 screws on the bottom. The drain pump will be right in the center usually white in color. There will be about a 3 inch piece that can be unscrewed by hand. Have your wet vac ready because when you start to unscrew this all the water in the machine will come out here. Once all of the water is empty completely unscrew and pull out. You will now be looking at the drain pump screen which with the f2 should be full of lint or debris. Clean the screen thoroughly and reassemble. If this does not fix your problem you will need to check all the hoses going into the drain pump for anything blocked in them. If all is clear you will need to check for 110 volts at the pump when the washer is in drain. This should only be attempted if you have had training with live voltage. If 110 volts exists the drain pump will need to be replaced.
Thank you
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
134 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
