Question about Garden
Toro 20045 Mower will not start. Battery is putting out 13 volts and all I get is a slight grown.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
While the battery may be putting out 13 volts...it may not be putting out enough amps to turn the engine over...try charging/replacing the battery.
Posted on Apr 20, 2009
Toro wheel horse 13-38xl lawn mower won,t start, makes buzzing sound when key is turned on,checked solenoid with screw driver but will not start motor, tuned pulley under motor and wheel on top of motor...
If you crossed the two battery terminals on the solenoid and the engine did not turn over, I would check the battery terminals first to see if they are tight. Then check the terminals at the solenoid to see if they are tight. If all of this is tight and you are sure you have 12 volts at the solenoid, then your starter is bad.
Aug 23, 2013 | Garden
I need to find out what the voltage output and the miliamp output is on a toro z4220 mower my battery keeps going dead i have replaced it once already Thank yoy
You should have around 13.1 volts at the battery as the engine runs. If its 12 volts or lower - check or replace the voltage regulator. To check the regulator, stop engine, remove regulator plug, get a ohm meter and put the black lead to any ground,and touch the red lead to all the terminals one by one on the voltage regulator - you should get 3 readings - one lower than the other. If you dont get any readings - the regulator is definitely bad
Don in Baltimore
May 02, 2011 | kawasaki 48'' Toro Com Zero Turn Lawn...
Ridding mower not charging battery
Get a v12-Volt test meter and check your battery for 12+ volts not running. Then start the engine (you can jump with auto) and check voltage to see if it is higher 13-14-Volts.
The battery's available tend to be poor quality and is not unusual to have a new one fail. (new being 8 months or less)
Any further questions feel free to ask.
Nov 24, 2010 | Toro Garden
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i...
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Oct 24, 2010 | Toro Lawn Mower With Toro Power Tools
Tractor wont start unless I jump it
How old is the battery? When you get it started put a digital volt meter across the battery terminals and with the throttle about 1/2 open check the voltage. If should be over 13 volts DC if your charging system is working ok. If it is over 13 volts your battery has probably just given up. Lawn mower batteries are only good for 2-3 years. A trickle charger can extend the life if used.
I hope this helps.
Jun 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
I have a problem with the charging system or coil on my toro 52 inch lawn mower. I have replaced the 25amp fuse but when i take the postive battery cable off while the mower is running to check if there is...
I had the same problem
1) find your voltage regulator 3 wire- the one at both end
should be your ac voltage around 20 volts the mildell one will be your 13 volts DC go to the batterie or starter with your engine running, if no voltage there check the rotor with a ohmeter the wire at both end for open circuit or ground circuit with the motor off
p.s. the voltage regulator has to be ground
Apr 11, 2010 | Toro Lawn Mower With Toro Power Tools
Engine wont start just get a click
Charge you battery or get a new one and you will click no more!!!!
Apr 07, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 264-h toro mower that will not start. I
#1 clean battery connections, to bare metal.
#2 check for loose ground wire, usually at engine mount bolts
Aug 06, 2009 | Garden
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
281 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
