Question about AMD Athlon XP 2700+, 2.167 GHz (athlonxp2700+) OEM / Unboxed Processor
Got computer used for cctv - tried to copy incident on dvd and drawer would not open so i could put in blank dvd - tried to unclip and pull door open on dvd driver - computer said that ide cable unplugged cant see where unplugged and now computer not showin anything on monitor ?? pls help need to get cctv back up and recording.
  • thenewpenny Apr 19, 2009
    ide cable that is the red ribbon one this should also be in back of dvd drive ? how can i power down if nothing showin on monitor - do i just switch on and off at plug ?
  • 3,267 Answers
Check all power cables going into the DVD drive plus the IDE cable slot(next to the 4 pin power connector, at the rear of the drive). Assemble everything together and power down. After 3 min switch it on. It should be working now...........sodeep
Posted on Apr 19, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Apr 20, 2009
    yes that the simplest way & the ide cable is flat with one edge marked red..............sodeep
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Invalid disc error
Most likely you need to replace the drive, they are very cheap on ebay. Here is how to replace it 1st power up and open tray then unplug. remove front of tray, it unclips at bottom, pull out and up then slides off. remove screws and take the entire drive out. Remove base plate of replacement drive and screw down into the two rear mountings. Remove facia of Recorder and cut out the three little pieces of moulding directly above where the tray drawer will be, this prevents the drive from being forced down at the front. With facia off fit the drive back onto the now screwed down base plate. Replace facia, connect drive power up and open drawer then unplug. On the drawer front cut off the centre small moulding because it doesn't line up with the cut outs in the drawer, the other two do, slide the front downwards onto the drawer then press at the bottom till it clips in. Job done. My 5005 now reads much faster and recognises all discs prior to this Invalid Disc on everything, cleaned lens and it would then only see pre-recorded films etc but no blank discs.
Mar 06, 2011 | Lite On LVW-5005 DVD Recorder
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
Can't get the door open to put in a DVD. Player says no disc but the door won't open with remote or manually.
If you look at the front panel of your CD player you will notice a very small hole. Using a VERY straight Paper Clip push in about 1/2 inch in this hole then pull the drawer out.
Mar 07, 2010 | Cyberhome DVD Recorder - DVR1600
H07
H07
Spindle motor drive error
Oct 18, 2009 | Panasonic DVD-RV32 DVD Player
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
DVD drawer won't open and no audio on home theatre system
As far as with dvd and cd players in many devices they usually put a tiny hole under the dvd/cd tray. If you open the door with a precision screwdriver and look beneath the tray for a tiny hole and insert the screwdriver into the hole you will feel a gear, push a little more and this is the "emergency release" the disc should pop right out if it is a tray (not a front loader like ps3!) for the audio i need some more info like connections and what cables are being used, analog or digital. hope this helps you out.
May 05, 2009 | Electronics - Others
The DVD drawer will not open
I have the same problem. Best way to open the door is to hit the eject button and then bang lightly on the door using the remote controller. Works every time.
Mar 31, 2008 | GoVideo Go Video DVD/VCR Combo
Coping dvds ,cds
If you are copying a DVD to another blank DVD, just put the original DVD inside > open Nero > click Copy disk > then the copy dialog box window will appear. > Just select your favourite speed ( [8x] medium speed recommended) and click Burn. If you are copying a DVD to your hard disk, just put your DVD on the drive, Open My computer > right click DVD drive icon and click open > Then select the appropriate file or folder to copy > right click it select copy > close the window. Now open My computer > open disk drive [may be D: or E:and so on... ] > right click and select paste. Now the file will be copied to your disk.
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
AMD Athlon XP 2700+, 2.167 GHz (athlonxp2700+) OEM / Unboxed Processor Logo
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
