TX-RS6O5 Please need code for AT&T U-verse remote control. AT&T gave me about 39 codes, but: One is working in "OFF" mode and non in "ON" mode. Please can you help me ????? Thank-you Luigi Frigoli Mail: a109epower@yahoo.com
SOURCE: Code for Verizon FIOS remote Control
i have a konika television set and i can not get it to turn on or off with the verizon remote. I went through the booklet and it said to press the >> unitl the television set went off but, I pressed it until the end of the list and it never shut off. what can i do?
Posted on Apr 05, 2008
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
SOURCE: What remote control code does the Onkyo TX-SR304 use?
From: http://www.comcast.com/remotes/universal.html - only worked for me when I had AUX setup with 30135
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL , VOL-, or MUTE will control the device's volume only in its own mode.
If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
Posted on Apr 15, 2009
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
Posted on Jun 03, 2009
Nov 25, 2015 | Televison & Video
Dec 31, 2012 | Onkyo TX-SR705 Receiver
Nov 13, 2017 | Universal Remote Control DIRECTV Universal...
Mar 12, 2011 | Televison & Video
Jan 23, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Jan 11, 2010 | Onkyo TX-SR605 Receiver
Jun 28, 2009 | Olevia LT32HVM 32 in. LCD Television
Jan 22, 2009 | Televison & Video
Dec 30, 2008 | LG LFD790 System
Mar 02, 2008 | Durabrand DWT1304 13" TV
210 people viewed this question
