HP vp6320 Multimedia Projector Logo
Laurie Posted on Sep 25, 2013
Projector shuts off after a few minutes, has an odor
Total shutdown after after a few minutes
This is a power supply failure.
infocus.dex.com
5E.13440.003 PCBA, POWER BD$78.90
1helpful
NEC NP 1150
The temperature in the classroom is to hot. Turn down the
temperature in the classroom or get a small fan and place it near the
projector. The projector is running at border line and just needs a few
degrees of cooling...
1helpful
Projector cuts off after a few minuts of powering
i suspect the device has cooling issues. the shut down is done to prevent physical damage to the machine's delicate electronics. make sure that none of the airvents are covered and try to remove dust using a can of compressed air. if this does not help, you chould contact a local repair centre for maintenance.
Model PJ556D will run for a few minutes and then shuts off. Once it cools down it will start back up, but shuts off again a few minutes later.
Hello, Greg.
The most common reasons are the temperature is too high or the ventilation holes are blocked.
Unplug the AC power cord, wait 5 or 10 minutes then turn back on.
There could be dust or the air filter needs to be changed.
Take the lamp cover off the bottom. It's possible that the screws holding the lamp are loose.
Hope this helps.
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
1helpful
My viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
k24674
Grand Canyon Tech
Grand Canyon Tech
