Question about Dryers
Dryer not drying after 70 minutes
My dryer is not drying thoroughly. I have it on for 70 minutes and the clothes are still damp. There is heat and the clothes aren't extraorinarily wet. Help! it is a Maytag
    Problem Solver:
  • 4 Answers
Your dryer could possibly have 2 heating elements and 1 has burned out, I had that problem once.
Posted on Apr 19, 2009
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
Heat does not go on and stay on clothes tumble but are still damp they never completely dry in 70 min.
sounds like a venting problem, check vent tube for restrictions, you can take the tube off and run the dryer, should have hot air blowing out, if you do then it is the vent tube if not then you will have to clean the inside of the dry out with a vacuum. Good Luck Tim
Oct 25, 2010 | Kenmore 73952 Gas Dryer
Won't dry clothes thoroughly
It could be or the moister sensor is bad. Do this first for most people never think of doing this. Disconnect the entire venting duct work. Inspect it and clean it. If you get a wad of lint every foot length from this vent this will be your problem in drying clothes. The clogged vent will not let the exhaust pass through and the moister sensor detects that and shuts off the heat automaticly
Apr 20, 2010 | Whirlpool LER7646E Dryer
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Doesn't move hot air to the outside
Clear obstruction to hose outlet.
Vitally
Jun 02, 2009 | Dryers
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
After 40 minutes of drying clothes are still damp... there is some heat
you need to check the wall vent hole to make sure it's not clogged,check the dryer vent hole to,most of the time a dryer does not dryer good because the clogg is holding in the hot damp air-mike
Feb 23, 2009 | Dryers
Dryers Logo
100 people viewed this question
Top Dryers Experts
