External hardrive wont transfer data
The chip on my wd 500 gb external hardrive isent working i let a friend barrow it and the usb connection was slightly bent i put it back in place but now it wont transfer any data but it shows its powered up
  • tigerpyro Apr 19, 2009
    it actually has five pins and i checked to make sure the pins are touching
  • tigerpyro Apr 20, 2009
    yeah i switched the hardrive its self into my other external and have it working now thanks
Looks like the usb connection pins are not touching the other connection pins. just check the pins touch each other surface then the data will transfer. check all four pins. if it is a standard A connector then far two pins are power supply and middle two pins are data pins.
v- data- data+ v+
the above are the pins in a standard usb connector
Posted on Apr 19, 2009
  • Anonymous Apr 20, 2009
    you said the usb connection is bent. is it bent in the connector of usb drive or the connector of usb cable.
    it is mini usb connection right....
The transfer speed is too slow for my WD elements portable 500 gb. overnight it cannot copy 20 gb of data. what is the problem?
Possible problems include having antivirus or antispyware programs sunning that have to check all data transfers in progress. This is a massive resource load on your machine. Turn off them and adware while doing the transfers.
Another problem might be real bad fragmentation of one or both of the data devices.
When defragging, you need to do that in SAFE mode to avoid it taking days... every change it makes during defrag it goes back and runs scandisk unless you do it in safe mode.
Annother problem would be severe data errors causing error corrections continuously.
Feb 12, 2011 | Western Digital Elements powered by WD 320...
I plug my external hardrive into my labtop and its not reading it at all as if I never plugged anything in
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 29, 2010 | Western Digital 500GB My Book World...
My WD800 hardrive fell down and now its not
Try connecting it to some other computer, and see if you can retrieve it. Also try a different OS too if it does not work.
May 17, 2010 | Western Digital External USB 2.0 80 GB...
Hi there, my Western Digital External 500 GB hard drive wont get recognised - it is blinking rapidly and it was working fine a minute ago - no physical shocks etc
Try to connect to another usb slot or try on another comp if you can,if it still won't work then your HDD has hardware problem which can be solved only by a WD service.
Jan 24, 2010 | Western Digital My Book Home Edition 500...
My WD external does not connect well to my laptop.
sounds like the drive heads are broken or out of line the unit you have does require a power cord its the data cord that it doesn't need , suggestion is to remove the driver heads and replace them with new ones from a matching Drive , its all you can do to save your vital files , if you are willing to replace your heads I can assist you however its not an easy task
Jan 11, 2010 | Western Digital My Book Essential Edition...
Archos AV500 / USB harddive
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
Seagate 500 external hardrive
It could be that the PCB or the connection within the external casing has a problem.
Try disassembling it and putting the Hard Disk into another external case to see if the disk is okay, if it is then viola! you have your data back.
Jan 14, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
