Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Electric panel not working
I am unable to engage most of the control panel and most of the numbers, however some do work, so it is not a blown fuse. Also the convection will not engage. Oven is five years old, started lossing a few button first, then other stopped working.
    Sergeant:
    Champion:
  • 362 Answers
You have a common problem for that oven the key pad fails from wear try to find a replacement it should be fine after that.
Posted on Dec 08, 2007
SOURCE:
Controls for ac not working on 1998 buick century
see this steps and fix it. God bless you
Start the car and turn the air conditioning on. Allow the engine to run a few minutes so the air can cool. Check to make sure you have the proper buttons selected. This simple step may uncover the root of the problem.
  • 2 Adjust the air controls on the dashboard to see how they are working. If the controls move the way they should with the proper amount of resistance and stopping in the right places but have effect on the air, then the problem may as simple as a blown fuse. If the controls are not working at all, then the problem is in the control panel.
  • 3 Get to the fuse box in a Ford Explorer by removing the instrument panel to the left and slightly below the steering wheel. There is a fuse remover provided in the fuse box. A blown fuse will have a broken wire in it. In a Ford Explorer, this fuse is red number 10.
  • 4 Find the control panel by prying off the top instrument panel around the air conditioning temperature controls. Unscrew four screws, one in each corner, and remove the temperature control panel. Unplug four electrical connectors and one vacuum hose to the control panel.
  • 5 Listen for the blower motor to be properly working while the engine is running and the air conditioning controls are turned to high. Adjust them from low to high to make sure the blower motor noise increases and decrease accordingly.
  • Oct 04, 2012 | 1998 Buick Century
    2003 monte carlo AC on off button does not work
    I have provided a possible solution for this.
    Jun 20, 2012 | 2003 Chevrolet Monte Carlo
    2004 ford taurus ses
    Wich fuse for the radio system would you like to replace? There are 6 of them. Your integrated control panel (dash unit) is controlled by the rear electronic module. This is all part of the multiplexed computer network in your car. I would recommend BEGINNING diagnosis of your radio by scanning your computer network for fault codes, then go from there...
    Even if there is a blown fuse, this is an indication that there is an electrical failure which must be diagnosed and repaired. Blown fuses do not cause electrical component failures. Electrical component failures cause blown fuses. Replacing a blown fuse without diagnosing and correcting the fault that made it blow will only result in another blown fuse.
    Please also review the following article:
    Where's The Fuse?
    Apr 12, 2012 | Ford Cars & Trucks
    What can cause a no power condition to ac compresor on 1996 Lincoln town car?
    Instructions1 See if the problem is as simple as a blown fuse. It is probably a blown fuse if the temperature controls on the dashboard seem to work correctly but have no effect on the air. The fuse box in a Lincoln Navigator is located by the brake on the left lower side of the steering wheel. Pry off the fuse panel cover and find the blown fuse.
    2 Have a look at the control panel next, if the controls are not working at all. First disconnect the negative battery cable. Detach the shift lever cover, and then the electrical connector. Unscrew the screws holding the trim cover on the shift panel. Disengage the four clips to pull the trim panel off.
    3 Unplug the electrical connectors, remove four more screws, open the audio unit cover the whole way, disengage the clips in each corner and remove the climate control panel.
    4 Listen for the blower motor to be properly working while the engine is running with the air conditioning controls turned to high. Adjust them from low to high to make sure the blower motor noise increases and decrease accordingly.
    5 Find the blower motor in a Lincoln Navigator underneath the passenger side lower trim panel. Push the carpet back. Unplug the electrical connection from the blower motor, remove four screws and pull the motor out.
    Thanks
    Apr 02, 2012 | 1996 Lincoln Town Car
    DRYER STOPPED RUNNING. ALL CONTROLS WORK, BUT WON'T START. HIGH LIMIT SWITCH GONE?
    It's either of the thermal fuse on the blower housing or the thermal fuse on the heater enclosure is blown. These thermal fuses are wired in series with the motor and therefore, if any of them is blown will cause the motor not to run and hence the dryer not to work except the controls.
    Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
    Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
    Bypass the thermal fuse on the blower housing by disconnecting the wires and taping them together or connecting a jumper wire between them. Close the door then plug and start the dryer.
    The dryer should start and heat up if the blower housing thermal fuse is the culprit. Otherwise, the other thermal fuse on the heater enclosure is blown. Unplug the dryer then bypass the thermal fuse on the heater enclosure in the same way the first is bypassed to confirm it.
    Plug the dryer back then restart it. The dryer should start to confirm that the heater enclosure thermal fuse is blown. Replace the thermal fuse (part number 307473) together with the high-limit thermostat (part number 303396).
    Unplug the dryer and unbypass the blower housing thermal fuse then plug it back and restart it. If the dryer fails to restart, replace also the blower housing thermal fuse (part number 33001762) together with the cycling thermostat.
    Reinstall the front panel in reverse steps of the removal steps to complete the repair.
    Aug 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    2000 vw jetta Remote key no longer works, electric...
    try the 10a fuse for the light inside,the symbol on the fuse panel is a light with a line on the top, it controls alarm and windows too
    May 21, 2010 | 2002 Volkswagen Jetta TDI
    Was drying and just stopped. Panel is still working
    One of the thermal fuses is blown. These thermal fuses are wired in series with the motor and will cause the motor to stop if one has failed. One thermal fuse is mounted on the blower housing near the air outlet duct while the other is mounted on the left side of the heater housing. The fuses fail when an overheating problem occurs. Clean the lint filter; check and clean the exhaust ducting for any lint build up. Lint build up prevents proper ventilation and cause overheating problem that leads to the failing of the thermal fuses. Once these fuses fail, the thermostat associated with it must also be replaced. But it is recommended to replace both thermal fuses and thermostats as a preventive measure. The parts will cost about $50. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
    Access to the thermal fuses and thermostats requires the removal of the front panel. Open the dryer door and remove the four screws located vertically along the inside lip of the door opening and securing the front panel to the front shroud assembly.
    The front panel is held to the cabinet by clips on each side secured to the cabinet front flange. Small slots in each side of the front panel engage the clips and hold the front panel in place. Grasp the front panel post near the top cover then pull the front panel away from the cabinet.
    Tilt the top of the front panel away from the cabinet and lift it up to release it from the two clips retaining its bottom to the base of the dryer, and then move the panel away.
    The thermal fuses and thermostats can now be accessed. Locate the blown thermal fuse with the aid of an ohmmeter. Set the ohmmeter to X1 and disconnect the wire from one of the thermal fuse terminals, and then touch the ohmmeter test leads to the thermal fuse terminals. The thermal fuse is blown when the ohmmeter reading is open (infinite); otherwise it is good.
    The thermal fuse on the blower housing is located to the left of the cycling thermostat while the other one is on the left of the heater housing.
    To replace the parts, disconnect the wires from the parts and remove each mounting screw then pull the part off the assembly. Install the new part and secure each with the mounting screw. Reconnect the wires and reinstall the front panel back into position. Secure the base of the front panel to the clips on the base of the washer then push the front panel posts to the cabinet engaging the slots with the clips. Secure the front panel to the front shroud assembly with the four securing screws.
    Note: Blower housing thermal fuse: part number 33001762; heater housing thermal fuse: part number 307473; cycling thermostat: part number 33002567; high-limit thermostat: part number 303396
    Mar 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    Brake lights and cruise control stopped working at the same time?
    Ther is a recall on the brake light switch it makes the cruise control not work too. but Chevy only recalled the Brake lamp Switch. Recall #09049.Hope this helps.
    Jan 01, 2010 | 2006 Chevrolet Colorado
    The electric door and miirors are not working
    Normally the owners manual will have a diagram of the fuse panel and what fuses are where. It may be by number with a table that has the names. Then you'll have to take the manual to the fuse panel so you can tell which is the top and bottom.
    You could also just take fuses out one by one and look through the side to see if they are blown. A good fuse will have no breaks or burnt spots in it. A blown fuse will have a gap somewhere. If there's a doubt, get an ohmmeter and test it. It should be less than a half ohm, but a blown fuse will be open.
    Sep 01, 2009 | 2000 Jeep Grand Cherokee
    OVEN CFEF372BC3 electric control panel not working
    Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
    Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
    Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
    156 people viewed this question
    Top Jenn-Air Kitchen Ranges Experts
    Thomas F. Schneider
    Paul Carew
    Ismael Rodriguez...
    Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
