Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model MDG5500AWQ
Light stay on wity message 8.8. but don't do anything before it was resolving with keep dryer time low or high and fix the time some time work but since couple days no respond. just 8.8. stay on none of keys working. Can you tell me is still under warranty or not. My address is 44660 Fenwick dr, Canton MI.48188 Pls help us with the warranty ans. and tip for troubleshooting.Dryer does not operate. 8.8. is displayed but will not turn on. This is a Maytag Neptune MDG5500AWQ DRYER
  • 262 Answers
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Posted on Jan 17, 2008
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
  • 43501 Answers
SOURCE: My maytag neptune dryer won't start. The control
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
Posted on Jun 01, 2010
  • 10865 Answers
SOURCE: My Maytag Neptune model MD9800AYQ electric dryer
Hello Jazz,
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Oct 07, 2010
  • 3051 Answers
SOURCE: I have a Maytag Neptune
Hello there again you can post me a comment in this section if needed about the dryer ok
Best regards mike
Posted on Dec 06, 2010
Maytag gas dryer LDG7500AAL flame won't stay on longer than about 5 seconds.
The resistance is too weak in the hot surface ignitor to keep the gas valve open and requires replacement.
Dec 22, 2013 | Dryers
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
My maytag neptune MDG5500AWQ will heat only on the wrinkle release button. How do I get the front off to clean out the lint. Can't get it with the vacuum. please advise
Here is a good link that will tell you what you need to know. I purchased and inexpensive kit from lowes that has vacuum attachments that will reach into very small cracks and crevices. It has been a very helpful item to have.
Make sure to check the vent on the outside, and the ducting that runs through the wall.
Be very careful, some of the places are very sharp, might be wise to wear some gloves, and be mindful of any wiring you could run into.
Hope that helps,
Jul 20, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is hooked up but it will not turn on; no lights, no beeps our Maytag Neptune is model number MDG5500AWQ please help
more then likely it is the thermal fuse:
here is a new one, may be cheaper on eBay or faster to get from a repair/service shop:
here is the location, it is on the bottom of this page, Good Luck Tim:
As a test you can tape the two wires together, make sure power is off and do not run dryer like this as it will cause a fire.
Dec 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer heats up but turns the heat and timing
usually the coils on the gas valve are going out
Oct 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
129 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
