Falshing f05 hotpoint wdf 740
Take a look at the info on the Hotpoint wd860 heater element i have put on here previously . Its probably the same think. probably a lot of fluff on the heater element burning a little and the safety system shutting down.. Dave
The fault is associated with drain out (pump blocked or restricted in some way). Try to clean it or contact Hotpoint support
SOURCE: hotpoint washer dryer wdf 740 showing error code F-13
F13 error code is a dryer NTC problem. What you need to do is take off the top of the washer. From there you will see the dryer chamber on top. Towards the front of this is the NTC it will have 2 thin wires going to it. Make sure the wires are on ok and not broken. If the wiring is fine then you will need a multimeter and test the NTC. It should give a reading in Kohms. If the NTC is fine then its possible the control board at the back is the problem.
Testimonial: "Very clear instructions and helped to eliminate a couple of possibilities, then pointed to the most likely suspect."
