Question about Microsoft Windows® XP Professional Full Version OEM for PC
On boot computer does not see Hard drives
Win XP Pro system, on boot system does not see HD's, can open BIOS setup and drives are shown, but not on boot.
  • 8 more comments
  • 4gotcha Apr 19, 2009
    This is a desktop and I can not boot into Windows in the normal way. If I use an Acronis bootable disk I can get into windows and it is working fine.
    From boot or reboot I can get into BIOS setup and have checked all setting and the hard drives are recognized. But when I reboot the only info that comes up is about the video card and ram then goes to the MB flash screen, that's it.
    When I boot or reboot the system, the first screen is with info about the video card and it's ram, that's all. Next screen is the ASUS MB flash screen saying press DEL to enter setup, but does not work.
    If I reboot and hold DEL I can get into BIOS Setup, and have checked all settings and hard drives are recognized. Save and reboot and back to the same MB flash screen.
    If I use an Acronis bootable disk and can access my main HD and it opens into windows with no problems.
    It is at the very first part of boot or reboot that it fails to read or recognize the hard drives.
    I have reset BIOS to defaults and hear no beeps on boot. Will try the mb chipset drivers.
    did the chipset, but now can not enter bios setup or use acronis bootable disk. hangs up at info screen 'can not tect temp device" and stops at "initializing usb controllers'. I'm at a loss?????
    mb is asus p5b plus and chipset ich8 raid. it keeps hanging at usb initializing.
    I think I found the problem, USB hub. Unplugged it and rebooted, and windows came up. So I think I got it. Will let you know later, going to buy new hub.
    Got a new hub, but same problem not recognized in windows and at boot hangs up at usb initialization. usb controller?
    Did disable usb in BIOS, but need for mouse and keyboard. Also have loaded windows then plugged in hub, goes through it's checking, but at the end message is "can not recognize hardware". But seems to work, but pain doing it that way.
  • 4gotcha Apr 20, 2009
    SP3
  • Timothy Farley May 11, 2010
    Hi there. Can you actually boot into windows? Also, is this a desktop or laptop?
    Sergeant:
    Novelist:
  • 192 Answers
Hi there.
Ok, there are a couple of things you can try. There may be a problem with your hard drive, you can test this with a program called SeaTools for DOS. You can download it from here:
http://www.seagate.com/www/en-gb/support/downloads/seatools/
You will need a blank floppy disk, as this program will make a bootable floppy. Once you have made the bootable floppy, just restart the system with the floppy in (You may need to change the boot sequence/priority in the BIOS settings). This will then load a Hard Drive Diagnostic program which you can then perform tests to see if anything's wrong.
You mention that by using a boot disk, you can load windows. SeaTools do have a Windows program that you can download and run from Windows. You can download that from here:
http://www.seagate.com/www/en-us/support/downloads/seatools
Another thing you can try, if you have an XP Pro setup disc. Boot from the CD, when it asks you if you want to Setup Windows, click yes. The CD will then perform a scan of your system and will tell you that you already have a version of Windows on the system. It will then ask you if you want to still Setup Windows, or if you want to Repair Windows. Click Repair. This will then re-install the system files for XP.
If you need me to clarify anything, just reply to this post. If this solves the problem, please rate.
Tim
Posted on Apr 19, 2009
  • 2 more comments
  • Timothy Farley Apr 19, 2009
    Ok, when you're in Windows (using the Acronis Boot), download and install your motherboard/chipset drivers from the motherboard manufacturer's website. Have you tried resetting the BIOS? Also, when it fails to boot, do you hear any beeps?
    Umm. Ok. What is your motherboard model? And what chipset driver version did you install?
    If you can enter your BIOS, disable the usb's
    Ok, keep the usb hub disconnected. Load Windows, plug in the hub, and see if it installs. What Service Pack are you running?
  • 3,267 Answers
Chose boot sequence to boot directly from the HDD . Also check if the Hard Disk is OK by connecting it to another PC. Check too that the power cables are snug tight and none of the pins are bent in the IDE slot. Now try booting first in safe mode & if successful go ahead and boot normally....sodeep
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
I can't load win xp
check the hard disk option in bios or load bios setup default then check
Aug 25, 2009 | Asrock P4I45GV R5 Motherboard
I con not setup win xp on the hard without floppy disk
Start your computer. Enter BIOS SETUP. Select "Boot Order". Configure to make the CD/DVD the *FIRST* boot-device. Put the Windows CD/DVD into the drive. Save/Exit from BIOS SETUP. Your computer will restart, and will "boot" from the Windows disk in CD/DVD drive.
Jun 08, 2009 | ASUS P4S800D-X Motherboard
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
I am replacing the hard drive in my Dell Dimension L866r
Do you have a floppy drive in the drive if so remove it. Also turn off your floppy drive or just remove it completely it could be bad sending false info to the main board saying there is floppy drive in the computer. Also try and turn the drive off in the BIOS
Jan 16, 2009 | Dell DIMENSION P3/866MHZ 128MB 20GB DVD...
Hard disk
if you are installing a dos based system thn dos formatting is very good
if you are going to use xp then make boot option in setup as bootable from cd rom
put a win xp setup cd in the cdrom drive
it will boot up saying press any key to continue , and follow the scren instructions
the whole process is that simple a hd can be formatted till bad sectors are not shown up upto 8 %. more thna 8& bad sectors cannot load windows, however dos can still be loaded and so also win me so it doesnot affect the hd
what affects is the jerks and voltage supply variations on the har d disk and some bad virus infections and the temperature the hd has ... always leep hd at a tem p lower than 37 degres c
use a fan to achieve this a 12 volt small fan mounted on the hd .
Jul 29, 2008 | Computers & Internet
Got a question for you...
The windows XP pro cd has the tools you need
DO NOT FLASH THE BIOS
DO NOT ERASE THE HARD DRIVE
sometimes when the hard drives are erased and they are SATA the bios won't recognize a RAW SATA drive.
  1. enter the setup utility and configure the BIOS Boot order to boot from CD/DVD
  2. insert Win XPPRO CD
  3. apply settings and save and exit
  4. reboots automatically
  5. press any key when prompted
  6. select the install
  7. select the primary partition you want and delete that partition.
  8. confirm you want to delete it,
  9. quick format to ntfs.
  10. once formated the loading of the OS is auto
Apr 19, 2008 | Computers & Internet
Where is Linux mbr file
There's nothing like the Linux MBR File. The option to boot to multiple operating systems is controlled by a software called as the "Boot-Loader".
Windows XP and Linux both have their versions of boot-loaders. The Bootloader that Windows XP uses is called the NTLDR, whereas Linux provides many bootloaders (prominent among them being "Grub" and "LILO").
>but Linux is shown in the manage option from the My Computer in Win XP 2.....
That is the control section of NTLDR. So from what I understand you shouldn't have a problem selecting the operating systems.
If you want the Linux bootloader taking control of the boot process, you can always install it.
All you need is a Linux CD and then run the setup for "Grub" or "LILO".
Information about installing Grub or LILO can be found easily on the internet.
Oct 19, 2007 | HP Data Protector Express Software...
Microsoft Windows® XP Professional Full Version OEM for PC   Logo
255 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
