Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My briggs & stratton will not start
My 18hp engine will not start I have fire and i cleaned the carb. if i spray starting fluid in the carb most of the time it will start for a second or two. I also replaced the plugs. Can someone please help me fix this problen.
  • 1 more comment
  • Anonymous Apr 30, 2009
    I have starting problem with my B&S 11hp rideon mower, so I'd pull down the head clean and adjust the vaules by grinding the steam (only the intake needed) and so all the vaules has the right gap now, but it still will not start, not even with a starter spray into the carb.
    My B&S is about 20 years old but hardly used.
    can any one help me nutting out this problem?
    thanks
  • Anonymous Mar 17, 2014
    450 series Engine keeps cutting out after starting, cleaned plug, replaced fuel
  • Anonymous Mar 29, 2014
    Need carburetor for 6hp lawnmower engine
I had a similar problem on a 20 hp v twin. there was trash in the fuel shut-off solenoid screwed in the bottom of the float bowl stopping fuel. It will come out without pulling the whole carb apart.
Posted on May 28, 2009
  • 469 Answers
If the engine fires on starting fluid, then you are missing fuel, so you need to start with the source, is fuel getting to the carb? if not why not. Check fuel lines, shut off valves and filters.
If it is, is the carb float allowing the bowl to fill?
If there is fuel in th float bowl, then you need to look at mixture and idle settings.
hope this is of some help.
Ed
Posted on Apr 19, 2009
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
What is the best way to clean out a clogged fuel system? I believe I put old fuel in the tank and now it won't start.
First pull the fuel line off at the carb and drain the fuel from the tank into a can. Put the fuel line back on the carb. Put fresh fuel in the tank.Try a spray of starting fluid into the carb to see if it will fire.If it fires do this a few times till it stays running.
Sep 13, 2014 | Heavy Machinery
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
B&S 18HP will not start
check compression squirt a shot of starting fluid in the carb see if it wont start check all your safty switchs
Apr 24, 2013 | Briggs & Stratton Garden
My B&S 18hp Intec engine on my lawn tractor will not start but it will backfire??? Will not run
You may get lucky and have a sheared keyway on the flywheel . Just a lil off can make a big difference on timing.
Jul 28, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
The firwt time this year I tried to start my Briggs Troybilt Pressure Washer, it will not pump gas. I spray gasoline in to the carb and it starts for a moment. I spray gas in the cylinder, and it fires for...
If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton 2550...
I have cleaned the carb for 20 hp briggs and stratton engine and still cant get it to run
Not sure what you mean by 'run'. Engine needs fuel, spark and air to run. And the fuel has to be in an exact proportion to the air.
Air is easy, temporarily remove the air filter.
Fuel is tougher - I would recommend you get starting fluid and spray down the carb (now that you have air cleaner removed).
Spark is toughest. There are some tools that can verify there is a spark and there are some more expensive tools to verify the strength of the spark.
If you have spark, the engine should at least fire up. If the engine dies a few seconds later, you don't have fuel flow. Carburetor is still not working.
Is the carburetor fuel bowl full of gasoline? If not, check filter and needle and seat.
If you have fuel, make sure the jets are clean. The carb sucks fuel out of the bowl via jets. This empties into the carb's venturi (the throat). Take spray cleaner and spray down the little passage in the throat (not into the engine) and you should see the cleaner spray into the fuel bowl. If not, try spraying through the jets and watch the spray come into the venturi.
When air enters the engine, it causes a vacuum that sucks the fuel out. This is physics. The only way it doesn't work is if there is a clog in the system.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Can get the engine to fire by spraying starting fluid into the air intake but will not continue to run. Fluel is getting to the carburetor.
Hi, it sounds like a problem with the fuel not going through the carb. This could be a plugged jet in the carb, or the float is stuck, or set wrong. Are you getting fuel in the carb bowel? If so, then it probably is the jet. This requires you to remove the bowl and clean every orifice you find. Use a good carb cleaning fluid for this. A good auto store will have this in a pressurized can.
joe
Jan 09, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
Briggs and stratton engine model #31H777,type0297 E1,code041014ZA-motor turns over but won't start-getting fire at the plug also plug is wet with gas.
there are the basic things for an engine to start. air, fuel, and spark. if you are getting spark at the plug one down. try taking your air cleaner off and spray starting fluid into carb with choke open then close. if it starts and runs a litlle then dies then you have a fuel problem. take carb off and clean real good take bowl off and clean with carb cleaner. that should solve you problem if not let me know
Dec 24, 2010 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,952 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
