Question about Abit KN8 Ultra Motherboard
Manual I am looking for the motherboard manual for abit kn8 ultra because we have moved and i can not find my one. I hope you can help thank you l c smith stanthorpe queensland
  • Anonymous Dec 25, 2007
    ye me to i lost mine can eny 1 help
    Sergeant:
    Champion:
  • 293 Answers
ABIT = http://www.abit.com.tw/
Posted on Sep 19, 2007
SOURCE:
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
No sound drivers for MB kn8 ultra.
Go to the Abit website and download them.
Dec 27, 2009 | Abit KN8 Ultra Motherboard
ABIT KN8 Motherboard will not start
Seems like the start-button or the wire connected to it is broken instead of the mobo. Basically when you press the start button you short the 2 cables together. Try replacing any shabby looking parts of these 2 cables, and if here aren't any, try to replace as much of the cables as you can. Just try some basic copper-wire, preferrably insulated, and that should do the trick.
Jul 22, 2009 | Abit KN8 Ultra Motherboard
Can't install windows XP on my KN8 ultra
I believe you are using a sata drive not ide, correct? The problem is that vista has built in drivers to support your boards sata/raid controller, winxp does not. to work around this you need to go here -
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=KN8+Ultra&pSOCKET_TYPE=Socket%20939
Abit website. for your board - socket 939. KN8 ultra file called NVRaid Installation disk. click on picture, it will download the zip file. extract the files to an empty folder (create one). Then run RFDgen.exe program. It will create the floppy you will need. I hope you have a floppy drive, if not try a usb one. If it has a problem creating the floppy, copy the files in the folder floppydisk to your floppy. there is a readme.txt file in that folder as well that should help explain which option you should select when you install windows. So... once you have the floppy start your computer up with xp disk in and as the screen turns blue, you will see at the bottom of the screen a message - press F6 to select additional drivers. Do just that, a couple of times to be sure. then it changes to press F2, just sit back and wait. eventually it will come to a screen asking if you want to specify additional drivers. press S and the next screen will show you the drivers it found on the floppy. select the one for your configuration (can be changed in the bios). and then windows will load fine. this is necessary for all new systems with sata/raid installing xp. take care.
Feb 10, 2009 | Abit KN8 Ultra Motherboard
Abit KN8 ultra chipset coller
Try cleaning with compressed air.But i believe the bearings in rthe fan are bad..replace new.RichardM69
Nov 30, 2008 | Abit KN8 Motherboard
Motherboard ABIT KN8
i dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you hear..how long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Oct 29, 2007 | Abit KN8 Ultra Motherboard
Abit eq software
Does it vary? If it changes, it's probably a bug. If it stays static, it could be either. Try installing a different version, ask ABit Support, check the forums, etc.
Sep 30, 2007 | Abit KN8 Ultra Motherboard
Abit EQ Temperature Monitor
If SpeedFan is showing the correct temp for the same sensor, and that temp varies, then it's an ABit EQ bug. Frankly, I've never been impressed with the latest round of Windows software that ABit/Asus/etc. have been bundling with their motherboards. I suspect they're outsourcing the development, and the programmers are better at "pretty graphics" UI's than solid functionality.
Abit KN8 Ultra Motherboard Logo
289 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
