Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwasher zanussi aquapulse
I have power but cannot get a cycle to work the power light comes on but not any cycle lights do
  • 2 more comments
  • tiggy1 May 27, 2008
    I have power, but dishwasher seems locked, I cannot change settings and it just isn't getting started. Have tried usual, power on & off, door opening & closing, just nothing happening at all
  • dirtdish Sep 19, 2008
    I have an amana dishwasher adb1500awb. the control panel lights up, but when you push "on" nothing happens... help
    I have a load of nasty dishes waiting to be washed!
  • tonybevans Jan 06, 2009
    i have the same annoying problem, please help someone....
  • Anonymous Mar 14, 2014
    zanussi dishwasher not draining and tripping power on automatic cycle
  • 209 Answers
This sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Posted on Sep 19, 2007
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
My Zanussi aquapulse de 6654 will not start. Only the on/off switch light lights.
Hi, I have a zanussi de6965 had the same problem the only indicator light that works is the on-off button.I had a problem some years ago with my machine would not work and showed L3 as the fault as I remember. I was advised to switch off all power isolate from the wall is best(pull the plug out of the socket) I removed the front casing held along the top and down the inside by a number of small screws. You need to leave the two bottom screws in(one each side) Wiggle free the top half of the display panel to acess the box holding the PCB board.it's very fiddly you will need a sheet of paper and a pen to make a noet of the connecting sequence of the wires ( Mark the blocks of wires with numbers... when replacing everthing this should eliminate any problems) Remove the PCB board from its casing and turn over to expose the back. At the bottom left hand side I discovered two dry joints, I needed a magnifing glass to check all the joints just incase. The faulty joints were a little discoloured blackened slightly. Solution...I cleaned, fluxed and re-soldered the joints. When re-assembled all the parts. It will help when dismantling to keep a note of the number and size of the screws and where they were removed from.
My dishwasher is now working again. hope this helps.
Sep 23, 2011 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Is my zanussi aquapulse de 4744 dw hot or cold water fed ?
It is more than likely hot water fed. You can trace the line probably to under your kitchen sink and see where the line follows up to your hot/cold on your sink. There would be then another line coming off the hot which would lead to your dishwasher.
Jan 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
Zanussi Dishwasher Model no DE6744 Not working
HI. After me fiddling about with the machine,checkingto make sure water was available to it and trying to locate the float switch (whicu i didnt) .
Then i left it standing overnight aqnd the believe it or not it worked in the morning.
I let it run through the cycles of a program which it did ok.
Hoping it carries on ok. Kenethyorky
Aug 11, 2008 | Dishwashers
Zanussi aquasave dw24
hi there sounds like your door latch switch could be at fault.
hope this helps
Nov 08, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Stopped Working
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
http://www.qualityelectronicrepairs.co.uk/lists/laundrymodels-zanussi_1.html
Sep 25, 2006 | Zanussi 24 in. DE6744S Free-standing...
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
519 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
