Question about Panasonic NV-GS17 Mini DV Digital Camcorder
Getting onto pc and tv
Can u help with an easy way to connect to tv and wat cables i need to do this please
  • Anonymous Dec 28, 2007
    how do i put it on my pc
Firewire?
And ean, just use the 3.5mm jack at the front to a Red/white/yellow wire.
Posted on Jul 23, 2008
Hi...juz wanna know wat wud be d possible solution
You don't say whether you use an antenna or cable company. If you use an outdoor antenna then you'll need to get a converter box to get stations now that everything is digital. If you're on a cable system and you have basic cable(no box) then you need to get in touch with the cable company.
Oct 01, 2014 | Televison & Video
I was given Netflix (stream-in) for a gift, but can not get it to come onto our tv. Please help.
Your TV must be a 'smart' TV i.e. it should have software enabling it to connect to the internet and access features such as Netflix. If you don't have a 'smart' TV then you can purchase a set top box which can be connected to your TV and will allow you to access on-line services such as Netflix. If you have a 'smart' TV then you still need to connect it to your internet router, either with an Ethernet cable or via WiFi if the TV has WiFi built in (or you can buy a WiFi adapter for the TV). If you connect with an Ethernet cable then the TV will connect to your router (and internet) with no further setup. If you use WiFi then you will need to access the WiFi settings menu on the TV and configure the settings for your router.
Jan 19, 2014 | Computers & Internet
How we can connect pc to tv
Hi
I'm writing this post on how to connect your PC or computer to a TV because last week I returned from a trip in India and wanted to show all of my pictures and videos to my family from my laptop onto our HDTV, but unfortunately I did not have the correct cords and so after fumbling around for 30 minutes trying to connect my computer to the TV, I had to tell everyone that they would have to wait till the next weekend! Pretty annoying considering the times we live in, it should be quite easy to connect the two together!
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Jun 21, 2011 | Computers & Internet
How do I get my PC video signal to my TV. I s there a way with a wireless router and how will that be connected to my TV. Thank you.
Hi, you can use basic video cables to get your TV to act as a monitor. It depends on which ports your computer and TV have. You can use an S-video cable, a serial cable (with the blue connector that many monitors use), an HDMI cable, or a DVI cable. If both your computer and your TV both have any of these same ports, all you need is the cable and you can have your TV receive video signals from your computer.
Hope that helps!
Sep 28, 2010 | Computers & Internet
How do I connect my digital tv converter box to this plasma tv. My antenna in and signal out are both co-axial cable. Which input do I use on the back of the tv? Would I use a BNC adapter to coaxial...
Here is a cheap and easy way to connect this for you....
Get a VCR (often times can be found at goodwill or garage sales for very cheap) and connect the coax cable from the output of the Converter box to the Antenna/Cable in on the VCR then connect from the RCA output from the VCR to the TV. Tune the VCR to Channel 3 most likely and change channels through the converter box.....
Good Luck and please rate this solution....
Jan 05, 2010 | JVC GD-V500PZU 50 in. Plasma Television
I triped over the cable cord. Cable cord end that protrudes fron TV was broken off. need to replace it so I can get cable reception.Please Help .Other wise the T V was showing great.
I'm sorry to tell you this ... when this happened with the TV at work (a camp;ing resort), we found the "F" connection was mounted to a printed circuit board attached to the 'motherboard' of the TV. The board was more than $100.00. We bought a new board and the new kid got to it before I could and he mixed up the wires. After the technician was done with it, the bill was another $250.00.
What I can recommend to you to prevent future damage is dont connect the cable to the TV -- get a short piece of cable and fasten your TV to a "F" fitting stand-off which would be firmly mounted to non strategic part of your TV. Then connect the cable to the stand off. Next time it is pulled on, it will pull the end off your cable (fix for a couple bucks) and not tear the guts out of your TV.
The parts are probably available to you. Make sure you have the right parts in your hand before you do anything ... and then take lots of pictures and notes as you remove the old and insert the new.
I hope this helps you ...
a
Oct 08, 2009 | Televison & Video
S-video problem for inspiron 6000
You will have to look at your TV to see what type of interface it has for PC connectivity, this is because there are 2 types of Video out on the laptop, first the s-video and secondly VGA (D-SUB).
I would recommend the VGA connection as the quality of the picture will be much better than s-video, so you will need a male to male VGA cable if your TV takes that interface (a male to male mini stereo cable is also required for audio)
If your TV only supports s-video then you are stuck with that interface until you upgrade your TV.
If you need anymore help in this matter please don't hesitate to post back.
Regards
Jun 29, 2009 | Dell Inspiron 6000 Notebook
TV will not work when connected to laptop with av cable
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpg This information is from the owners manual for your model Sony (PCG-GRZ610) PC Notebook computer found on page (57) has a diagram and procedure for making the correct connections. You must make sure you have the correct connection cables and have set both the television and computer for external signal output source (notebook).External signal input source (television). The cable connection is listed below and follow the web page link to see the correct procedure for getting the laptop computer and the television working together. This procedure is explained in the notebooks owners manual on pages (112) (113) (114) you will also need to look in the televisions owners manual to see the procedure for switching the input source to external, so it can see the computer's signal. The owner manual copy is listed as the user's guide. You will also find customer service available on this web page. They will be able to help you with any problems you might be having with the set-up between the computer and television not explained clearly to you in the owners manuals of the laptop and television. I hope this information helps you solve the problem of making the connection between your laptop and television. Thank you for using FixYa and have a nice day! http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCGGRZ610
May 07, 2009 | Sony VAIO GRZ610 Notebook
Wat cables do i need to get picture from my laptop to tv
hi
you need a PC RGB cable which plugs into the back of your laptop then into your TV also an audio lead again from the laptop to TV
hope this helps
Nov 04, 2008 | Computers & Internet
Usb problem....please help!
if u want to connect through a USB cable u need to install a suite for ur samsung phone called "handset manager / easy studio"....after that u can fix the cable at both ends and transfer ur data and applications on ur phone with ur pc...
Sep 29, 2007 | Samsung SGH-E900 Cellular Phone
Panasonic NV-GS17 Mini DV Digital Camcorder Logo
57 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
