Question about Sony MPF820 Internal Floppy Drive
I installed floppy drive in a desktop that never had a floppy drive, but I can't get A:/ to appear in My Computer. Do I need some sort of driver?
  • rohit asthana
    rohit asthana May 11, 2010
    did floppy drive installed in your computer???
    Sergeant:
    Novelist:
  • 192 Answers
Hi there.
No you don't need a driver, as they run on controllers. If the system never had a floppy drive before, then you will probably need to turn the controllers on in the BIOS.
When you turn the system on, keep pressing F2, or Del. This will open your BIOS settings screen. The first screen you should be looking at, tells you the time and date. It should also allow you to change any floppy drives you may or may not have. If you can't change them, then you may need to have a look through all you settings, and find the one called FDC (Floppy Drive Controller). Make sure it's Enabled. Once you have done this, save and exit. The system will reboot, and you should now have access to the floppy drive.
If you need me to clarify anything, just reply to this post. If it works, please rate it.
Tim
Posted on Apr 19, 2009
When i switch on computer the screen comes up with Drive1 not found:SerialATA,SATA2 Floppy diskette seek failure Strike the F1 key to continue,F2 to run the set up utility
Ok. It sounds like something happened inside the BIOS settings for the machine. Most PCs todays do NOT have 3.5" floppy disk drives (drive A) anymore. There is a place in the BIOS where you select the type and size floppy drive connected as drive A. One of the options is "NOT INSTALLED" . If your BIOS setting shows a floppy drive and there is none present, every time you boot up it will give the Floppy disk seek error you mention. Next time your boot, select the F2 option. Check to see if a floppy drive is selected. If so, change to NOT INSTALLED. Also, there may be on the advanced page an option of "Floppy seek at bootup" . You can disable this and that will help as well.
Jan 05, 2012 | Computers & Internet
Am trying to reistall Win XP. Have run Fdisk and reformatted HDD. PC will not recognise install CD, keeps coming up with errors, does not find CD or HDD. Hav also tried running setup from floppy, again...
IF the hard drive is a SATA hard drive, you will first of all need to download the SATA drivers for te motherboard and copy them to a Floppy drive on another computer if yours will not work, this may also affect why it is not "seeing" the Cd drive if this is a SATA one too
Try installing Windows and when the message " press F6 if you want to ...." appears, have the floppy inserted in teh floppy drive so it can find thr SATA drivers, it will then recognise the Hard drive and install
If you have further problems please repost
Jan 03, 2011 | Gateway GT5056 PC Desktop
Where is the disk drive for a floppy disk located at on the tower
Sorry, but it appears that the EMachines model W3503 does not have a floppy disk drive installed. See this link: http://reviews.cnet.com/desktops/emachines-w3503/1707-3118_7-32178774.html
Floppy disks are obsolete at this point. If you have data on a floppy disk that you wish to retrieve, see about getting help from someone you know who might have one on their computer system, or visit a public library (you might be able to offload the floppy disk contents and e-mail them to yourself).
Most people use USB flash drives now. They are far more reliable and have enormous capacity. Definitely get one if you don't have it. The W3503 computer has several USB ports on it.
May 19, 2010 | E-Machines W3503 PC Desktop
How to create floppy with SATA drivers (NO mobo CD)
Don't need to use a floppy - copy the files to a USB Flash drive, and when the Windows asks for the source, select the drive.
Apr 22, 2010 | Intel Motherboard
My acer desktop with a MCP73 motherboard is not loading windows. it keep asking for drivers and does not find the hard drive, any idea, please
Dear, Do you have the CD/DVD came with the system board. you have to create one driver flopy using this disk. And, when you start to install windws, you can see one message Press F6 to Install a Third Party Driver
Insert this floppy in to your floppy drive at this time. It will load the driver from floppy. After this you can proceed normal installation
Oct 13, 2009 | Gateway GT5685E Desktop Computer - Intel...
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
Nexxtech External Floppy Driver Problem
Normally windows will install any driver for a usb floppy drive automatically. If it needs one. I'm surprised that it hasn't just worked by plugging it in as there cheap floppy drives over purchased have all just worked without the need to install drivers on win xp and higher. Remember you won't see the drive appear under my computer until it has a disc inserted in it though.
Jul 17, 2017 | NexxTech USB External Floppy Drive (NEFD2)...
Configuraton of my computer for aSmartdisk Fdusb-tm2
You need to find and download drivers for the drive, this usually isn't the case though if you are using an up to date opertaing system.. serach online for "Smartdisk FBUSB- TM2 Drivers" and this should sort out the problem after you install them and re-start the laptop..
Oct 13, 2007 | SmartDisk (RF-FDUSB-TM2) (RFFDUSBTM2)...
Sony MPF820 Internal Floppy Drive Logo
193 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
