Question about Vizio L32 32 in. LCD HDTV
Vizio remote i have directtv and just bought vizio tv, i can only change channels with my direct tv remote, with the vizio i can turn the tv on and off, change pic quality but not able to change channels or use pip
  • Anonymous Mar 13, 2014
    change channels manually on vizio m401ia3 tv
  • Anonymous Mar 16, 2014
    problem when changing channels
    Problem Solver:
  • 13 Answers
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Posted on Apr 19, 2009
I have purchased a new vizio Tv and have loaded all the commands from Vizio on to my DirectTV remote but the volume and on and off commands will not work on my directtv remote but everything else work
You need to enter the device codes for your TV into the remote. Sometimes there are multiple codes for a given brand so you may have to try more than one to get all functions working.
How do program my DIRECTV remote control DIRECTV Support
Dec 20, 2014 | Vizio Televison & Video
Directtv control code for Vizio
Your Direct TV manual should list all the mfg. codes for the remote. If you do not have the manual you should be able to read it and/or download it on the Direct TV website.
Jul 04, 2014 | Directv RC32 Remote Control
No Signal
Reboot ur DirectTv box.By unplug,replug it and hour later to let the box upgrade it solfware.Go to ur tv menu setup rescan it again for all the channels.It should work now.
Mar 14, 2010 | Vizio VO47L 47 in. LCD TV
When I turn on the tv, I get the Direct tv signal
It ur Direct tv converter box,unplug and replug or turn power switch off/on again so the box can reboot get a new and updated informations.It well back in the air if not must call the direct tv customer service for the disk check,it not ur tv.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
No instruction for my remote
hello there well maybe try typing the model of the remote on search ..would probably hep ya remeber to add what you are looking for make model and search for specs or try info...this may help you
Feb 05, 2009 | One For All URC-9910 LCD Remote Control
Cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
Mar 20, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Vizio L32 32 in. LCD HDTV Logo
487 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
