Question about Texas Instruments TI-34II Explorer Plus Calculator
Frozen display and keyboard after battery replacement
I have a TI-34 II calculator which needed a new battery. I replaced the CR2025 battery in the correct polarity and got a brief flash of the red light next to the battery clips. The the calculator reads "ANS>F" and will not turn off or respond to keyboard commands. Is it worth repairing? thank you
  • Texas Instru... Master
  • 8,068 Answers
Press [ON] and [CLEAR] at the same time to reset the calculator
  1. if you get unexpected results or
  2. it refuses to turn on, or
  3. screen goes balnk.
Posted on Feb 03, 2010
Where is the = on the Texas instrument TI-34 multi view?
Look for a key at the bottom right of the keyboard. It should be marked = or ENTER, or EXE. And please, read the manual if you hope to use the calculator efficiently.
Aug 17, 2014 | Texas Instruments TI-34 Multi View...
How can I get the manual for the TI-34II
TI has a quick reference guide. You can download it from this page.
Jan 11, 2012 | Texas Instruments TI-34II Explorer Plus...
Need instruction manual for TI-34 II
Hello
At the link below you will be able to downlad the user manual for the device requested. Just click on the link below, and choose the "Get Manual" option to download.
http://www.retrevo.com/s/TI-TI-34-II-Explorer-Plus-Calculators-review-manual/id/421ci272/t/1-2/
Kind regards
Andrea
Feb 02, 2010 | Texas Instruments TI-34II Explorer Plus...
TI 30X II S operation
This is a not a calculator problem, it's a physics problem. You need the formula: E = hf, where f is the frequency and h is "Planck's constant" (6.626068 x 10^-34 m^2kg/sec).
On your calculator, punch in 3.0 [EE] 12 [x] 6.63 [EE] -34 to get the answer.
Dec 08, 2008 | Texas Instruments TI-30X-IISTK Scientific...
I need to add variables on my calculator
To save enter the number you want to save then press [STO] and the variable you want to save to.
And to use the variable you need to recall it by [RCL] button and then the variable you want to recall.
Rate me, thanks.
Dec 03, 2008 | Texas Instruments TI-34II Explorer Plus...
TI-83 PLUS
Most likely your battery is dying.
You can replace by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 06, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Problem
Either battery is dying, or circuit board has gone, or connector cable loose.
You can replace battery by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA for $10 from Amazon, Staples or elsewhere.
Nov 04, 2008 | Texas Instruments TI-30XA Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Error message
I fixed this exact problem on my TI-5006 II calculator by simply replacing a "dead" battery. Three of the four battery's were good (after cleaning their terminals) but the fourth was completely bad (i.e. read "Replace" on my Battery Tester). Other problems probably can cause this exact same error message but this cure was simple and cheap. The problem first appeared after the calculator was dropped. A sudden shock (dropping it) can cause even a good battery to fail.
Jul 05, 2008 | Texas Instruments TI-5006 II Calculator
Texas Instruments TI-34II Explorer Plus Calculator Logo
247 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
