Question about LG Prada KE850 Cellular Phone
Changing words in T9 when texting?
I used to be able to change words in T9 when texting by pushing the arrow key at the top of the screen in the middle of the sentence area. Now it only skips to the next letter or is used as another space key like the 0_ button in this format. I can't switch up words in t9 and its driving me nuts. Does anyone know how to fix this??? or at least change it back to having the arrows function as word modifiers instead of a second space bar?
Thanks, I've been having the same problem and it was driving me crazy!!!! Thanks for sorting it for me!
Posted on Jan 10, 2008
Press the centre of the centre line where you should be able to see four arrows in a N, E, S, W sort of formation. This switches the arrow functions around.
Posted on Sep 25, 2007
I still dont get it
Posted on Sep 24, 2008
I have an older lg.wen I txt, I can't get 1 letter at a time
Besides the fact that you should get rid of that ancient device as they make life difficult lol you have to change the settings from t9.
When you are in the texting area you only have to hit the right key to change from t9 to Alphabet (not sure it's the exact spelling for t9 but one of the keys (usually bottom left or top left corner will allow you to type normal or to guess words by what you type, some of which can be confusing.)
for the letter e you have to push the 2 key 3 times I believe, if you keep pressing each key you will see different letters, numbers and symbols, perhaps a Users manual is available online (can google it, is available to tell you how to change the texting type.
Dunno this helps but it's so old I cant recall exact details but that's the gist of it.
Nov 22, 2017 | Cell Phones
How can one type with a normal typing keyboard rather than hitting abc for a c?
If your phone only has the numeric pad you can change the setting from "abc" to "T9". T9 is a predictive texting mode, so if you wanted to type the word "hello" you would just press the corresponding numbers 1 time, for example: 4(gHi)-3(dEf)-5 (jkL)-5(jkL)-6(mnO), so you would only hit 4-3-5-5-6, if the word is not the first word displayed you can hit the next key which is usually either * or # depending on your phone. The T9 setting is usually changed by again hitting either the * or # key, or sometimes 0. It is also sometimes selected on the texting menu from within the message.
Learn how to use T9
Sep 06, 2011 | Cell Phones
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do you change the text (caps or numbers) when sending a text
By pressing the * key you can change between, Caps and numbers you may notice on the top of the screen changing to the following
  • abc (NO CAPITALS)
  • Abc (First letter will be a capital)
  • ABC (All capitals)
  • Abc_ (Dictionary mode/T9)
Jan 16, 2011 | Motorola Mobility TracFone® V170 Cellular...
I dont like t9 texting on my phone.... i turn it back to abc texting, but it keeps changing back to t9.... it getting aggravating to have to keep turning back on abc everytime i go to text sumeone...
1. From any text field, tap the arrow next to the input panel icon. Options... 2. Tap
Enter text tab, choose Input Method 3. From the an input method. 4. Tap .ok
Some of the input methods may not be supported according to the language.
You can also set options for some input methods
please rate this if useful it only takes 1 second!
Dec 20, 2010 | Samsung SGH-I200 Cell Phone
How do i get the t9 off my text messages on a samsung d900???
ABC, T9, Number, and Symbol modes
You can enter text in some features such as Messages,
Phonebook, or Calendar, using ABC mode, T9 mode,
Number mode, and Symbol mode.
Changing the text input mode
• Press the right soft key to change the text input
• Press and hold [ ] to switch to Number mode.
• Press and hold [ ] to switch to Symbol mode.
Using ABC mode
Press the appropriate key until the character you want
appears on the screen.
: ABC mode : T9 mode
: Number mode : Symbol mode
Apr 07, 2010 | Samsung SGH-D900 Cellular Phone
Cant change my measage in t9
Hi there, i just bought the same phone. When you are writing a message in predictive text and need to change a the word for example from "me" to "if" then use the up and down arrows.
Prada's text editor relies on arrow buttons that are drawn over the text itself. The on-screen arrow keys have two modes, which are toggled by tapping on the small 4-way arrow in the middle. When set to left/right, the arrows can be used for moving back and forth in the text. When set to up/down, they are used for choosing alternate T9 word suggestions.
Hope this helps!
Kind regards,
Apr 29, 2009 | LG Prada KE850 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
Other T9 mode operations
• Press [1] to enter periods or apostrophes
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Texts random letters and then sends on it's own
have you tried to change the TEXT T9 from iTap to just ENGLISH
Dec 29, 2007 | Motorola Mobility RAZR V3
Text messages
u hav to press on the part of the screen where ur typing till a faint down arrow comes there. press that and change the word. if the word is not there you must create it in the t9 function. to create a word from scratch press on the part of the screen where your typing a few times and the press options then press create word.
Nov 05, 2007 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
178 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
