BITS clocking I am curious if the ALU7750 SR-12 has internal bits clocking that can be pushed to all the cards on the box? Also, is there MR-APS support on the ChOC12 cards? I am about to roll out a big deployment and someone said this platform was a good one. Anything I should be aware of? overview of setup dual chassis TDM/Ethernet setup with Cisco 6500 interoperability. Infrastructure layout is purely transport with minimal QoS configurations.
    Scholar:
  • 34 Answers
Http://www1.alcatel-lucent.com/comps/pages/carrier_support_america.jhtml
MR-APS is a Cisco specific Tech, although Alactel does have it's equivalent
Posted on Nov 16, 2007
SOURCE:
Transfer case replacement costs
transfer cases are those bits that are bolted to the rear of a gear box to give ratio changes and drives to front and rear wheels. On some vehicles it can be done in vehicle as the case has external bolts and slides onto a splined output shaft from the gear box . On others the whole case has to come out as the bolts are internal. I am curious as the heading is for an X type jag 2004 and is it a 4 wd
Jul 18, 2014 | 2004 Jaguar X-Type
There seems to be power going to my Mr. Coffee (the clock face is lit- though the clock face is blank). However, when I push the "brew now" button nothing happens. I changed outlets and still nothing. I...
Does the bottom pad get warm? If not it maybe a relay on the control board or most likely the element is bad. You can change this out but it is probably more cost effective to just purchase a new one.
Aug 21, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Where can I buy the hollow center torx screwdriver that fits mr coffee
Go to a Harbor Freight store near you or on-line to get a kit of 100-piece security-bits for about seven dollars on sale. The kit contains about every design imaginable and has about 9 or 10 torx bits with hollow centers. Hope this helps!
Jun 27, 2010 | Mr. Coffee TFTX85 Coffee Maker
Hello, I have a Worcester 24i boiler, it has a round clock with a grey outer ring,that can be pushed in(the grey bits around the clock), I would like to know how to set the timer on this boiler, it's...
When the grey bits are pushed in the boiler is set to come on for that 15 min incriment. Push they grey pins "in" for the required length of time you want the heating on and then set your manual on off switch to the middle position which will activate the clock to run through the set time sequence you have put in.
Sep 30, 2009 | Heating & Cooling
Maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Mar 26, 2009 | Mr. Coffee FTX49 12-Cup Coffee Maker
Baxi boiler timer
1)Push all the little pins (bits) inward toward the centre of the dial
2)Set timer to correct time by
turning dial to current time, ie if present time is 4.00 p.m.
Turn the dial until 4.00 p.m is aligned with the arrow symbol
3)PULL OUT all the ( bits) toward the outer edge of the dial to set the time that you want the heating to come on .eg pull out all pins between 6.00am and 9.00am(as each pin represents 15 minutesyou should have 12 pins pushed out)
4) Ensure the3 way switch in the middle of dial is in the middle position(timer) if it is at top position boiler is(constant on)and at bottom positon boiler is turned off.
Feb 02, 2009 | Hardware & Accessories
Puzzel 35p,dice on cards. Clock tower
the dots on each die represent the hands on an analogue clock.
ie
A=12
B=9
C=6
D=3
Hope this helps
Dec 27, 2008 | Nintendo Professor Layton & the Curious...
Cards with dice on, finding Raymond
D does not correspond to A, B or C, it corresponds to a number like A B and C do. If you look at where the dots are, they correspond to a clock.
A has two dots (even though you can only see one) on where a 12 would be. ie = 0 like 00.00 o clock = 0
B has a dot on 12 and a dot on 9 ie. 09.00 oclock = 9
C has a dot on 12 and a dot on 6 ie. 06.00 o clock = 6
D has a dot on 12 and a dot on .......
Does this help?
Dec 26, 2008 | Nintendo Professor Layton & the Curious...
I fill the resavior w/ water for a 12 cup Mr. Coffee and 2 1/2 cups evaporate while going through the motion and delivering less and less each time. I ran vinigar & water through 3 X's to no avail.
Are u sure that the water is still not in the reservior? After the partial brew, CAREFULLY check / empty the reservior for the missing water. If it's still there, then u probably have a clogged perculator hole at the bottom of the reservior.
I just figured out how to correct a slow / partial brew problem for a 4 cup Mr. Coffee that left the water in the reservior...I have been using paper towels and napkins to dry the reservior and cover after use, and apparently bits 'n pieces of paper clogged the tiny little hole at the bottom of the reservior that the hot water perculates through
Multiple vinegar/CLK flushes may eventually desolve this paper clot, but I used my vacuum cleaner with slat attachment to **** the paper clot out.
Aug 29, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Open Questions:
Computers & Internet Logo
115 people viewed this question
Ekse
Alun Cox
