Question about Tappan TGF320 Gas Kitchen Range
How do you open top of stove to clean under burners -split coffee
See summary
  • cilla73061 Apr 19, 2009
    Ok. But how do I release it to open the top? I pull up on the stove and it won't release. Is there a clip in the middle - or sides to release?
    I see the clips on both sides. I'll try it. Push in on the clip correct? Thanks
    President:
  • 331 Answers
Cilla,
The top panel lifts up like the hood of a car. There is also a support rod on the right side to keep it propped up.
SG
Posted on Apr 19, 2009
  • 2 more comments
  • Tracy Farrell
    Tracy Farrell Apr 19, 2009
    Hi Cilla,
    The parts breakdown does not show any clips. However, that doesn't mean they aren't there! Here's a diagram I made for you. It shows where clips are commonly placed. Normally, you can use a screwdriver (flat blade) and press the clip in (while simultaneously lifting up on the top) to release it.
    Hope this helps!
    SG
  • Tracy Farrell
    Hi Cilla,
    Yep. You got it. Push in on the clip and lift the top at the same time.
    SG
    (p.s. Please rate my solution, deal?)
  • Leisa Sep 08, 2012
    I am having the same problem with the stovetop, I can't get it lifted up to clean under the burners. I TOTALLY HATE HAVING THAT OPENING where drippings & crud overflows to make such an AWFUL MESS!
    it looks like it should lift up like the hood of a car, BUT IT DOESN'T, I can't even get it to release!
Maytag advanced cooking system how do I open the top to clean under the burners
It is just held down by spring steel "friction" clips, lift the lip, it takes quite a bit of force the first time you open it.
Jul 10, 2017 | Maytag Kitchen Ranges
How do i open top of stove to clean under the burners
You can but I wouldn't recommend it . It is relatively sealed clean, but I will tell you anyway... there are three screws each under each burner that hold the top down to the burners so if you have 5 burners there are 15 screws to take off...put them in a cup so you don;t loose them after removing the screws ..go to the front lip of the top ..take a butter knife and put between the seam near the corners ..you will feel a type of spring resistance push in to release spring pressure and pull up on the corner of left and right of the top and remove top.. You will be surprised how clean it really is.
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Need help opening an older Caloric Prestige Series Range top
Generally you just need to place a flat blade screw driver in the crack about 3 inched below stove top and pry up, this exposes the entire under pan of the stove top.
Apr 07, 2014 | Stoves Kitchen Ranges
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
We took apart our kenmore gas stove because a rat had been living in it. We cleaned it up and now can't put it back together! We are looking for an assembly manual. Please help.
How do I open the top of my Kenmore stove to clean under it? I am trying to clean it because some of the burners don't want to light when I turn the knobs.
Jul 19, 2009 | Kenmore Kitchen Ranges
How do I access the spill tray under the element of a chef stove in order to clean it?
Make sure that all of your burners are off and cool. Raise the stove top. It should tilt from front to back. There will likely be rods inside to hold the top open.
--Regards, --WoobieDog--
Jul 10, 2009 | Electrolux Cooktops
Gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Mar 01, 2009 | Stoves Kitchen Ranges
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
BURNER ON STOVE TOP NOT WORKING
some dirt or spilled food is in the orfus tbue or holes forcing it to come out under the burner!
If you ever replace the unit, get sealed burners the you can take them off and clean them!
GET HELP.
THESE GUYS CAN HELP!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Tappan TGF320 Gas Kitchen Range Logo
257 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
