Question about Creative Labs Zen Touch MP3 Player
The buttons on the front don't work.
Everything works on my MP3 player except all of the buttons on the front. Volume, power, reset and the slider all work. But the 6 buttons on the front don't do anything, not even turn on the screen light.
  • Mark P Sep 21, 2007
    I don't know what resolved this issue. When I got back today I again tried to make the buttons work, but nothing. I then connected it to my computer to sync it up and transfer the music to my new computer so I didn't loose anything. When I got done and disconnected it from the computer I tried it "one last time" and the buttons worked. So I guess the problems resolved. I just don't know what "fixed" it.
    President:
  • 4,402 Answers
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Posted on Jan 21, 2008
SOURCE:
I`m not speak english very well my mp4 philips does not work i don`t know what to do
You need to hold the reset button in for a few seconds, 3-6 seconds, now go to the slider for the power, push it as hard as you can :) Don't be a city boy with it, it should power up if it shuts right off repeat but link it up to your computer next time before it cuts off so it can recharge. "Merlin"
Jan 08, 2010 | Philips SA3125\02 MP3 Player
Sansa e260 volume will not work?
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
Mar 10, 2009 | SanDisk Sansa e200 MP3 Player
I have problem with Sansa View
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Itouch volume realy messed up! plz help!
and you are sure the volume is all the way up? If the headphone jack thinks there is something in there the ipod touch will only play through the headphones. you can try to blow out any dust in there with a can of air and that might solve your problem.
Jan 27, 2009 | Apple iPod touch
Sansa display problem
-Tha Mp3 Doctor
Oct 27, 2008 | SanDisk Sansa e250 MP3 Player
Ny computer does not recognize my mp3 player
Use volume + method - except for vista users, who need to grab the Vista-compatible software from Sandisk's website:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
-Tha Mp3 Doctor
Sep 28, 2008 | SanDisk Sansa Clip MP3 Player
The buttons wont work!
The hold/lock slider is engaged - double check your manual to see the position of it on your player and disengage it
Jul 05, 2008 | Creative Labs ZEN SLEEK MP3 Player
GoGear 4GB SA3345
i have the same problem but am taking it further check out this link http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
Jul 02, 2008 | Philips GoGear Flash MP3 Player
YP-U2J Samsung mp3
just start mashing buttons....this happened to me and after a moment of panic...it worked!
Nov 20, 2007 | Samsung YP-U2X Digital Media Player
It does no start when i press d button
-Tha Mp3 Doctor
Aug 31, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs Zen Touch MP3 Player Logo
42 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
