Question about Lexmark E232 Laser Printer
Lexmark E232 A had paper jam, I fixed it properly. Now the Blue light is on. Toner light flashes. Paper light flashes. Paper jam light is on. What can I do.
  • 2 more comments
  • ghaffari Nov 22, 2007
    All the lights suddenly started flashing (blue and yellow ones) and I am not able to print. Any help would be greatly appreciated
  • hsl13 Dec 27, 2007
    All the lights suddenly started flashing (blue and yellow ones) and I am not able to print. suddenly the printer prints a something it can't be read...Any help would be greatly appreciated
  • Anonymous Mar 03, 2008
    Blue light will not stop flashing, and will not print at all.
  • compward4 Feb 10, 2009
    The printer had a paper jam. Ifixed it and now the blue light, Toner light & paper jam lights stay on
Huh?!
Posted on May 09, 2008
  • 163 Answers
Oh my GOD ,PLESE OPEN ITS ELECTRONIC BOARD AND REINSTALL IT PROPERLY
Posted on Sep 19, 2007
Toner not fitting after removed paper jam, I'm 100% sure how to put it in, it just doensnt go deep enough in anymore. Any ideas on whats wrong ?
Please try to check for obstructions inside the printer. Please click on the link below, this will show you how to properly install the toner. http://bitly.com/qLdxGT
If you need further assistance please contact Lexmark Technical Support Center.
Jan 29, 2011 | Lexmark E232 Laser Printer
Related t my Lexmark E232, I'm using a compatible toner but it put excess of ink in the papers. Then I bough a new original Lexmark toner, and when I put in the printer on two lights, from top the second...
Inspect the overall paper path for signs of spilled toner.Gently clean the contaminated areas with a soft cloth or compressed air.
Jan 24, 2011 | Lexmark E232 Laser Printer
AFTER PAPER JAM WILL NOT PRINT
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 20, 2010 | Lexmark E232 Laser Printer
Printer now very reluctant to pick up the paper from the tray, keeps reporting paper jam. Think this could be a problem with the rollers
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider2_bing.gif to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 15, 2010 | Lexmark E232 Laser Printer
Erre lights on Lexmark E330 what is second one from bottom?
error light on out of paper also toner light is flashing but its a new toner kit and there is no paper jam
Sep 30, 2009 | Lexmark E330 Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Printer not printing
you might need to check your driver if it is install correctly for the correct OS, i'm not sure what OS you are using but below link might be helpful to help solve your issue
http://etech.maiila.com/?p=42
all the best..
p/s please rate me...
May 29, 2008 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
641 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
