Question about Kenmore 22422 Top Load Washer
Finding Lint Filter on Kenmore 70 Series Model 110
I'm trying to find and clean the lint filter on a Kenmore 70 Series Model 110 (made by Whirlpool) Any ideas where the filter is located?
  • Jacqi Nolf Nov 21, 2011
    Thanks Katrina. I failed to say it was a washer and it is!
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Posted on Nov 02, 2011
  • 653 Answers
There should be a 3 inch by 8 inch cover on the right rear of the top of the dryer. Open the lid, grab the handle and pull the long wire mesh filter out. Clean off the lint and reinsert, curved side down.
Posted on Apr 19, 2009
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Does this washer supposed to have a lint filter
No Lint Filter sorry you have a basic design washing machine, Dont replace it though it wont do u any justice just pocketbook pain
Jun 17, 2010 | Kenmore 44932 Front Load Washer
Kenmore 70 series electric dryer not coming on
next time send the model number,if it's not starting unplug the dryer,on top of the blower wheel housing there will be a thermal fuse,if the filter is on top it's behind the back panel of the dryer,if the filter is inside it's in the front of the dryer,it will be near the duct that the lint filter slides into,you need to remove at least one of the wires before you read it out with a meter,it will be a 3392519 or a 3390719,these are the two most used thermal fuses.let me know what you find,if it is the fuse most likely you need to clean out the dryer.blow out the vent line i use a leaf blower if it's long,clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is
Apr 23, 2010 | Kenmore Dryers
Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Mar 18, 2010 | Kenmore 73952 Gas Dryer
My Kenmore 70 series is heating up but NOT drying. I checked the vents. They are clear. The exhaust from the back of the dryer seems to be pretty weak.
Good day,
The lint filter is supposed to do the job, but........
1. Remove lint filter.
2. remove 2 screws under lint filter, then pry up both front ends of the front of the top lid.
Lift lid up and prop up but do not go completely vertical.
3. Remove back cover of the machine.
4. Remove all the screws holding the vent shute on the left side.
5. Lift this shute out and up as far as possible, watching out for the wires.
6. Inspect the blower wheel and it's housing with a light. Should be filled with a buidup of lint.
7. Clean out and reassemble.
Dec 05, 2009 | Kenmore 74602 Gas Dryer
I need a part number for the lint screen fora 9200l series dryer i lost the manual please help
Hello there:
Whirlpool recommends
8557884 Whirlpool Kenmore Lint Filter (screen)
This Genuine Whirlpool dryer lint filter is used on Whirlpool, Kenmore, KitchenAid and Roper dryers.
Special Note ***** Does your filter have a black spacer below the handle?.
************ If so you may need the Whirlpool Dryer Filter 8557857
The 8557884 Whirlpool Kenmore Lint Filter (lint catcher) is about 17 and 1/2 inches long and has a white handle
Hope this is helpful for you
best regards Michael
Nov 30, 2009 | Whirlpool GEW9200L Electric Dryer
Kenmore 90 Series Washing Machine. Does it have a filter that needs to be cleaned regularly. I owned a maytag previously. It had a center post that collected lint etc. that needed to be cleaned. I...
It's an auto-clean internal lint filter. Lint is trapped from water circulating through the filter during the wash cycle. During the drain cycle it's backwashed and the lint goes down the drain.
Feb 02, 2018 | Kenmore Washing Machines
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer Model 66702692
Air flow may be blocked or restricted.  Make sure the lint filter is clean and exhaust duct and outlet are not clogged.
May 30, 2009 | Kenmore 62602 Electric Dryer
Kenmore 22422 Top Load Washer Logo
3,660 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
