Question about Acer Aspire 5100 Notebook
Keyboard not responding when loading windows xp
Ive loaded windows xp only to find the keyboard not responding when i get to enter name and orgainization im using usb mouse at the moment
  • 1 more comment
  • kiwifala Sep 19, 2007
    sorry forgot to add
    its a acer aspire 1640Z
  • Anonymous Jan 06, 2008
    same problem but its not a notebook
    keyboard is responsive before windows loads itself
    after windows loads it becomes unresponsive
  • ivagirl Jan 10, 2008
    keyboard or mouse not responding after windows xp load
Get out the battery and reseat it. and try again
Posted on Sep 20, 2007
SOURCE:
Ive just reinstalled windows xp and the keyboard and mouse are not responding so i cant access desktpo at all
Hi.
If both the keyboard and mouse are USB connections then you will have to wait a couple of minutes for the operating system to install the drivers for them, just keep on wiggling the mouse until the cursor moves.
If that does not work please post back.
Regards.
Nov 22, 2012 | LG Computers & Internet
Windows XP Boot Up
USB Keyboard take a while to register. Try a serial type keyboard if your system has the Purple serial port on the back.
May 25, 2012 | Dell Inspiron 531s Notebook
Hi everyone,Ive got a dell cpx 650Mhz s600gt.os is window xp.my problem is the screen did not display anything after booting,it comes black.but the system is opperating,no welcome screen.plese help and im...
Wow what an oldie!
Unfortunately XP is no longer supported. This machine was designed for Win98 and 98SE. I expect there is a display driver missing, along with a few more perhaps.
Try loading 98SE and if it is OK, XP is your issue.
Jan 23, 2011 | Dell Computers & Internet
Gateway 2005, windows xp, pentuim 4.trying to fix my girlfriends computer. We are in the process of instaling a geforce video card. I installed the video driver on on her harddrive with my pc. After in put...
is it a usb keyboard? If so it must be enabled in BIOS. Also if enabled OK, then when at desktop next,, unplug and re-plug into another usb socket and it should be detected and a driver will install, thaat may fix it?
Feb 18, 2010 | Computers & Internet
Hello.. ive had this computer with vista as its operating system, because im not used using vista ive reformat it to windows xp pro but after formatting screen goes blank.. what could be the problem?? the...
There likely may be no XP Drivers for this model. If thats the case your choices are Vista or Windows 7 (Windows 7 Only if the system is capable)
Friendly, affordable, REMOTE computer help!
Nov 23, 2009 | Computers & Internet
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Logitech mouse problem
I assume there is no second mouse on the system and you are using keyboard commands. Try the following in the device manager..
  1. Press Control-Esc or press the Windows key on your keyboard to bring up the Start menu.
  2. Using the up arrow key, highlight "Settings."
  3. Right arrow key to "Control Panel" and press the enter key.
  4. Use the arrow keys to highlight the System icon and press the Enter key.
  5. Use the right arrow key to select the Device Manager tab. (For Windows XP/2000 , use the right arrow key select the "Hardware" tab. Now use the tab key, select the "Device Manager" button and press the enter key.)
  6. Use the "Tab" key to select the "Computer Icon" at the top of the list of device icons.
  7. Use the down arrow key to highlight the Mouse icon.
  8. Use the right arrow key to open the mouse icon and verify there is a mouse icon that states, "HID-compliant mouse," and another entry that states the name of your USB device.
  9. If there are any errors reported on these icons by exclamation points or red X's, highlight these icons using the arrow keys and "Tab" to the "Remove" button and press the enter key. (For Windows XP/2000 , highlight these icons using the arrow keys and then press Alt-A keys. From the "Action" menu, highlight "Uninstall" and press the enter key.) When the "Confirm Device Removal" box appears, press the enter key.
  10. Once these icons have been removed, use the Tab key to get to the "Refresh" button and allow Windows to re-detect the pointing device. (If u r using Windows XP/2000 , press the Alt-A keys. From the "Action" menu, select "Scan for hardware changes" and press the Enter key.)
  11. Use the arrow keys to open the Mouse icon again and verify that there are no errors reported.
  12. Power down the computer system and restart Windows.
Apr 16, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Gateway notebook MX6930 trackpad issue
Has the left mouse button ever worked? If so when did it stop working, make a system restore to that date
Nov 17, 2007 | Computers & Internet
Acer Aspire 5100 Notebook Logo
307 people viewed this question
Ekse
Alun Cox
