Question about RCA HD52W59 HDTV Projection Television
My rca tv d52w17 won't turn on.
Every time i press the power button, the green light on the power button lights up for about a few seconds and turn off, then do the same thing 2 more times and stay off. i try to turn it on every day and it does the same thing. can someone please help me. i haven't been able to watch tv for the past 2 weeks.
  • 4 more comments
  • choumy07 Apr 19, 2009
    i made a mistake it is a rca d52w17
    my tv is a rca d52w17. i need to know what to do to get it work.
    why change the power cord. when i press the power button, the green light lights up and turnoff, and the the same thing 2 more times.
    how do i know which one to change. is there anyway to check to see which one is bad
  • choumy07 Apr 20, 2009
    the bulbs are good
  • choumy07 Apr 21, 2009
    my co-worker checked it out and told me that they are fine. But if you tell me where to put the leads of the multimeter, i will recheck them myself.
  • 6,784 Answers
Hi, you will need to replace one or all of the projection bulbs in your projection set. There is a circuit main board inside of this set and, if it recognizes any inconsistency within the bulb current, it will shut off the fly back immediately. i recommend replacing one or all the bulbs in this set. this will fix your issue. The bulbs and part numbers are listed below.
Blue - 263049 $255.95
Red - 263048 $245.95
Green - 263050 $254.95
Posted on Apr 19, 2009
  • 2 more comments
  • Michael Masters
    Michael Masters Apr 19, 2009
    OK, to your previous comment. i didn't mention anything about the power board. your power board is fine. The issue concerns one or all of the projection CRT bulbs. one or all may be blown.
    You can test each bulb by the use of a multimeter or a test voltage needle. Use the terminal points on the CRT bulb housing to test. connect the multimeter clips to the bulb terminals. if you get a reading from the terminals upon powering up the set, and the bulb doesn't light, this will confirm the bulb failure.
    Test each bulb in this manner.
  • Michael Masters
    Your power cord if fine as well. no need to replace the power board or cord. Its the bulbs.(CRT's, RGB)...
  • Michael Masters
    Michael Masters Apr 20, 2009
    what reading did your multimeter resistor when you tested the bulbs ?
  • Michael Masters
    Michael Masters Apr 21, 2009
    ok, there are two contact terminal posts that are hot. they are located on the base of each bulb. connect each meter clip to these terminal post. test while the set is powered up before the green led shuts down. if you register a current string enough to read the meter, it will confirm bulb failure. if the current is non existing, it will confirm power circuit failure.
    Sergeant:
    Champion:
  • 289 Answers
Hi..It sounds like a power supply problem.
Check the power supply.
thank u..
rate me..
  • Hariharanath V Apr 19, 2009
    hi..you need to change the power chord.
    thank u..
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
D52w17 big screen tv won't power on
Thats a common problem which means the Flyback and cp150 and CP114 need replacemnt. Your model used a couple different flyback designs but the following link can tell you which one you need and they provide free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | RCA HD52W59 HDTV Projection Television
Sounds like a faulty power inverter to me.
If it's covered under warranty, take it back to where you got it and ask them to cover the warranty for you.
If it's not under warranty, take it to a local electronics repair store that deals with TVs. Get a quote from them on the amount to repair it.
If it exceeds a third the amount you paid for the TV in the first place (ie if the TV cost you $1,200 and the bill exceeds $400) you're better off to get a new TV.
Apr 19, 2009 | RCA HD52W59 HDTV Projection Television
RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Will not start properly RCA D52W17
Replace CP150 , CP120 and CP114 that should take care of the Issue of hard to power up. You can get the replacement capacitors at the following link with free instructions.
Nov 23, 2008 | RCA D52W19 52" Rear Projection Television
RCA universal remote
Try it without a code. Turn your tv off. Press tv then press the on.off button and tv button at the same time. When it lights up, press play every five seconds until the tv powers off. Next press the reverse button every few seconds (sometimes takes a while), until it powers back on. When it powers back on hit the stop button to save the code.
Sep 08, 2008 | RCA Universal Remote Control
RCA HD52W59 HDTV Projection Television Logo
176 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
