Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My fuse keeps blowing on my neutral safty switch on my John Deere 10c backhoe. What would you recomend to fix it?
  • Jerry Cramer May 11, 2010
    You have a short in one of your wires or possibly a bad starter
  • Anonymous Apr 01, 2014
    keeps blowing a fuses
  • 246 Answers
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Posted on May 14, 2009
I have a John Deere GT275 that keeps blowing the F3 15A fuse. Any suggestions why?
Get a wiring diagrams and trace down each component the fuse powers and its wiring and find the short, no other way to fix it.
Jul 12, 2017 | John Deere Garden
What year is the following john deere backhoe 310G :t0310gx911769
You just go to the link I attached I'm sure you will get the solution of your problem.
Apr 25, 2017 | John Deere Garden
What's a hydraulic fuse on john deere 1550 backhoe
Here's the link and I'm sure you will get the solution of your problem.
Best Manuals
Apr 18, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
Where's the fuse box on a john Deere 310 se backhoe
The right side of the right console. Facing the right window.
Dec 23, 2015 | John Deere Garden
Keeps going into neutral popping in an out of gear
Hi Frank:
I'd start by checking the linkage for excessive wear. There will probably be a cam or spring loaded device that keeps the shifter linkage in the correct position. Sometimes an accumulation of contaminated grease/dirt can prevent the proper function.
Jul 01, 2015 | John Deere 310sj Backhoe
John deere 250 skid loader - purchased new in late 2001. every time i turn the switch to start the engine, it blows the fuse.
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
Oct 17, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
394 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
