Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Toshiba 46H83 HD Projection TV with distored picture
I have a Toshiba 46H83 HD Projection TV that has fine horizontal lines running through picture, causing it to be distorted. It comes and goes and sometimes the lines are finer than other times, when the lines are fatter and more pronounced. Is this worth fixing or is it a death sentence.
    Problem Solver:
  • 10 Answers
If you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Posted on Apr 19, 2009
Have vertical lines across the tv. Started as something that happened right when I turned the tv on (for 5 mins or so). Now it's all the time. Toshiba 46H83
you more than likely have a bad panel inside of your tv. you can have someone repair it but it's not recommended as it's pretty expensive. You should just invest in a new tv.
Jul 23, 2010 | Toshiba 46H83 46" Rear Projection...
TOSHIBA TV NO PICTURE
Sounds like blown invertor board that powers the backlights (if it is LCD or PLASMA). If your lucky and its just the invertor board blown it could cost anywhere between £50-£150 for new board (without labour).. if you are UN-Lucky, then the backlights themselfs may have blown which is *usually* an un-economic repair.
Apr 05, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
May 13, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Horizonatal lines on Toshiba 46H83
If the repairman you had look at the set is used to working on projection sets, have him come back and Re-Solder Connector Px801 (Edge Connector) On The G-Hyper Module. (Pins 1 And 2 Of Px801 probably needs to be Re-Soldered) Otherwise, find a different repair person.
Dec 19, 2006 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
233 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
