Question about Sony PVM-14L1 14" TV
Will not switch between S & composite inputs
Unless I'm missing something, my monitor is supposed to automatically detect and route outgoing signals, but while S-video and composite audio work fine, composite video is not working at all. Any ideas? Thank you in advance!
  • mharnick Sep 22, 2007
    Thanks for your time - it's not an outside issue...the monitor is not recognizing anything plugged into the composite video input side on either line A or B input. tried all the cables, tried everything...it must be a problem common to both inputs internally.
It is out side problem any cable loose or some button must have pressed by mistake is any components.
Posted on Sep 21, 2007
My tail lights don't work at all on my 2009 Ford F150 STX.
Do the stop light's ,turn signals work ? Plate light's ?
Principles of Operation
The smart junction box (SJB) monitors the headlamp switch position by sending voltage reference signals on multiple circuits to the headlamp switch. At any given time, one of the signal circuits is routed to ground. If the SJB does not detect any of the inputs to the headlamp switch is active (routed to ground) for 5 seconds, the SJB turns on the exterior lights and keeps them on for 10 minutes after the ignition switch is turned off (or 10 minutes from the time the SJB does not detect any headlamp switch input if the ignition switch was already off). If the SJB detects multiple circuits short to ground, the SJB implements a planned strategy depending on the multiple inputs received. If either of these situations occur, the SJB should NOT be ruled immediately as being at fault. This is normal behavior of the SJB design as it has detected a fault with the inputs from the headlamp switch.
When the SJB receives an input from the headlamp switch indicating a request for the parking lamps, the SJB energizes the parking lamp relay (internal to the SJB), which supplies voltage to the exterior lamps.
Free wiring diagrams here http://www.bbbind.com/free-tsb
Sep 16, 2018 | Ford Cars & Trucks
Where is the auto head light switch sensor located on a 2007 lincoln navigator
Autolamps It's a light sensor The SJB also monitors the light sensor with a voltage reference signal. The light sensor input to the SJB varies with the ambient light conditions. Principles of Operation
NOTE: For additional information on the perimeter lighting feature, refer to Section 501-14 .
When the SJB receives an input from the headlamp switch indicating a request for the autolamps, the SJB monitors the light sensor for the ambient light condition. If the SJB determines the ambient light level is dark, the SJB supplies voltage to the exterior lamps.
If the ignition switch is already in the RUN position and the vehicle enters darkness/lighted area (such as when entering/exiting a non-lighted tunnel during the daytime), the transition from light to dark (or dark to light) needs to last 15 seconds before the SJB turns on the exterior lamps. This strategy is to prevent the exterior lamps from unnecessarily flashing on and off.
The SJB does react quicker under extreme light conditions. If the SJB has detected a very dark condition, the exterior lamps are turned on after 1.5 seconds. If the SJB has detected a very high ambient light level, the exterior lamps are turned off after 4 seconds.
Aug 05, 2018 | Lincoln Cars & Trucks
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Where's headlight relay @ on a 2010 ford fusion 2.5
There is no relay for low beams , the ( SJB) smart junction box , a control module an fuse / relay center in one.
When the SJB receives an input requesting the headlamps on, the SJB supplies voltage to the low beam and high beam bulbs as necessary.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Multifunction switch
  • Headlamp assembly
  • Battery junction box (BJB) fuse(s):
    • 19 (40A) (low beams)
    • 26 (15A) (LH high intensity discharge [HID] headlamp)
    • 27 (15A) (RH HID headlamp)
  • Smart junction box (SJB) fuse 11 (15A) (high beams)
  • Ballast
  • SJB
  • Bulb(s)
  • Circuitry
Jun 20, 2015 | Ford Cars & Trucks
My monitor keeps on on and off when u press the power button.
Monitors often turn off when no video signal is detected.
the automatic switch off is manufacturer dependant; so I can't guess how long it would be before switching off. Most screens read for a short time something like "no video input detected"... can you confirm that this is happening?
May 02, 2011 | Computers & Internet
Turn it on iget audio add video flashis for one second then iget kind of a white or gray screen?
The message you're seeing is part of your monitor's ROM programming. It is its response to an input signal that it doesn't recognize. If someone makes a composite to vga adapter cable, it's because they can sell it, not because it works. While both composite and vga are analog signals, they are not at all the same format. The signal gets to the monitor via the vga connector, but it's still a composite signal. Your monitor is all wtf about it. You can make HDMI to DVI cables, but that's because they carry the same digital signal. There is basically no way to connect a ps2 to a pc monitor that doesn't have composite or component input, unless you spend extra money. That can be on either a signal conversion box, which cost at least $50 and might not work so good, or a capture or tuner card for your pc that can capture the signal and relay it to the monitor as VGA or DVI signal. Either method basically converts the composite/component to vga or digital. There is such thing as a ps2 vga cable, but it doesn't work under the normal ps2 operating system, only under ps2 linux. It's hard to find, too. No point looking for one cause you'd only get to play homebrew games of which there aren't many.
http://www.seekic.com/
http://www.chinaicmart.com/
Jan 11, 2011 | Televison & Video
Failure to monitor video
If you are using component of vga cable, the problem may be in the cabling.
VGA:
1. cable loose.
2. Pins bent in connector
3. bad cable.
Component:
Remember that the chroma and luminence signals are separate. This means that if the cables are swapped, loose, or just plain not plugged in, there will be color problems like the one decribed.
Composite:
If you are having this problem with a composite input, then the problem is circuitry and will have to te repaired. If you haven't tested the composite [RCA] input, now is a good time. If the composite input looks normal, then you know the problem is cables on the other input.
Dec 29, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
I have a hitachi 42 inch plasma tv about 4 yrs old. we watch tv on composite mode and recently it switches to analog every time i turn it off and back on. this is anoying because i have to switch back to...
Well, composite is still an analog signal format. What input does the monitor go to and is there anything plugged into that input? This is a fairly industrial model and has some features that you would not expect a normal tv to have. Check to see if there is some sort of default input selection in the menu or something along those lines. I have used these units before but I'm not familiar with the overall workings. I know there is signal sensing software on the monitor, for example it will turn itself off if no signal is detected for a while, 10 min is default I think. The issue is more than likely a setting that was changed. One other thing you can try, there are cards in the slots in the back. Put the signal you want to come up in the card slot of the input that it's going to automatically. This is a workaround of the problem, but it would do what you want it to.
Oct 28, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Sony PVM-14L1 14" TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
