Question about Poulan Garden
I need an operating manual for the poulan pioneer 2050 chain saw please
  • 2,176 Answers
Go to Poulanpro.com and on the right side of site type in model 2050 appaarantly there might be a type number associated with this but I looked at the number 5 and viewed a manual for this saw. It is 18 pages long. Good luck and if I have helped would you please rate this information accordingly. Thank you
Posted on Apr 19, 2009
GAS line diagram for Poulan 2050 Chain saw
The gas line goes from the gas tank to the carburetor and probably passes through the underside of the handle. The correct diameter hose is very important as it is used to form a compression seal with the gas tank using a coupling that connects to the siphon filter with a short length of tubing.
Feb 21, 2015 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Poulan chain saw 2050 2.0CL
The Poulan Chainsaw 2050 is a 36cc model with a 14" bar and chain.
Sep 02, 2014 | Poulan Garden
What is the petrol/oil ratio for the poulan pioneer 2050 chainsaw?
The fuel must be mixed 40:1. Also, the manual is here: http://www.mccullochpower.com/node4043.aspx
Just click on the first link. Good luck!
Jun 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Bar not oiling
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Sample IPL "Poulan 2050 Gas Saw Type 7" (there are almost 20 IPLs for this saw. I defer to you to find the correct 1):
http://www.ordertree.com/modelinfo/PWE/2050-Gas-Saw-Type-7/75.2050-Gas-Saw-Type-7.1.59.1.html
The oiler pump and worm gear are on the "Handle, Chassis & Bar Assembly" illustration. This also aids disassembly.
All Poulan IPLs can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
It has an outboard clutch, this is a guide for removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it). HTH
Lou
Feb 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
384 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
