Question about Konica Minolta magicolor 2300DL Laser Printer
2300 DL fuser roller
Does anyone have specific instructions for changing the fuser roller? I'm a bit nervous without a guide.
  • viska_ra Apr 19, 2009
    This was exactly what I was looking for. Thanks very much!!
  • 326 Answers
Hello. Thanks for choosing FixYa!
I have found a link to the service manual of your product:
http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
This will help explain everything in detailed steps, it will also explain any tools or preparation that needs to be taken before making a replacement or repair.
I would not be nervous at all about replacing the fuser. This is a common user replaceable part, which means the manufacture has gone to great lengths to make it as user friendly as possible to replace.
A word of caution, be careful handling the fuser if the machine was printing shortly before replacing the fuser. This will cause the fuser to be moderately to extremely hot. This is one of your only precautions regarding this replacement.
Instructions for replacing the fuser (Fusing Unit) can be found on page 95 of the service manual.
To avoid any issues with the service manual click the disk icon to save it to your computer. I suggest selecting desktop when the box asks to save, or anywhere your comfortable with and can easily access it.
If you need anything else, please let us know.
If you found this information helpful please take a moment to rate it.
Posted on Apr 19, 2009
I have Konica Minolta 4650 DN. I printed out a dark picture and put the paper back in the printer by accident. Now all my pages print smudged broken lines going down the paper. Please help me!
Just print 20 or 30 pages with nothing, or only a little dot or something. Your printer is polluted and needs to be cleaned. Sometimes it is enough just to run a few empty pages. If this isn't enough, look at your manual how to clean your drum and fusing unit.
Oct 03, 2011 | Konica Minolta magicolor 4650DN Laser...
OKI c5200 fuser is jamming, How to CLEAN IT b4 I try replacing it
There are not set instructions to clean the fuser rollers on the 5K range of printers from Oki, this is designed to be a consumable that is replaced at regular intervals through the printers life. this means there is little access to the rollers. Firstly, remove the fuser from the printer and allow it to cool down. At the rear of the fuser, on most models there is a flap that can be opened to give very limited access to the rollers. All that can really be done is to wipe the rollers with a soft cloth to remove any debris that has built up and turn the rollers using the gears on the side. The blue lever on top of the Fuser can be used to separate the rollers to make the task a little easier.
Nov 08, 2009 | OKI C5200n Laser Printer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
HP2420 Manual
Are you sure it's not the transfer roller that you want to replace?? this is the roller which sits directly under the toner cartridge, the fuser sits more towards the rear of the printer. I'll list instructions for removing both. Hope this helps
To remove the transfer roller -
1. Release the left end of the transfer roller by using needle-nose pliers to pinch two tabs at
the left end of the transfer roller.
2. Use the needle-nose pliers in the same manner to release the other end.
3. Lift the transfer roller out of the printer.
The left end of the transfer roller has a spring attached. At the right end of the roller, the
spring is attached to the printer rather than to the roller. As a result, the spring at the right
end remains in the printer.
To remove the fuser -
1. Remove the back cover and the I/O cover.
2. Remove the fuser-cable cover by releasing one tab on the cover, and then
rotating the back of the cover toward the center of the printer.
3. Remove the duplexer inlet guide by releasing two tabs on the guide, and then
sliding the guide toward the back of the printer.
Reinstallation tip
Make sure that both tabs snap back into place when reinstalling the duplexer inlet guide.
4. Disconnect two cables at the left, inside, of the printer.
5. Disconnect the fuser cable at the right side of the printer.
6. Remove four screws securing the fuser.
7. Tilt the fuser slightly toward the back of the printer, and then slide the fuser out of the
To remove the back cover -
1. Open the face-up delivery door all the way, and then press the door down to disengage
two door-stops.
2. Remove two screws
3. Close the face-up delivery door, and then tip the printer so that it rests on its front.
4. Open the "legal-size" cover, and then disengage one tab.
5. Lift the bottom of the cover first, and then lift the cover away from the printer.
6. Tip the printer back so that it rests on its feet.
To remove the io cover (looking at the printer from the rear, this is the small cover on the left side) -
1. Rotate the I/O cover to clear tabs at the right side of the cover.
2. Lift the cover off of the printer.
Nov 12, 2008 | Office Equipment & Supplies
Wrinkling in fuser area
If there wasn't wrinkling before the guide was changed, check for alaingment of the guide and any minor obstructions. Also, check the condition of the fuser rollers especially the lower pressure roller. Check for wear and the clear sleeve "gathering up", (if applicable. Did you do anything to change the pressure of the roller?
MM85
Jul 20, 2008 | Canon NP 7130 Black and White Copier
How to change the drum on 2300 DL
Turn off printer.
Open side door, remove waste toner box.
Lift blue bar (in direction of arrow) to release drum assembly.
Grip tab as shown in small image, press and pull drum assembly out of its slot.
Take NEW drum and slide back into its slot, pressing it into place over the metal guide pin.
Pull yellow tab to remove protective film from drum (discard this).
Lower blue bar to engage drum.
Replace waste toner box, close side door, turn printer back on and let it cycle to start.
That should be all there is to it.
Feb 11, 2008 | Konica Minolta magicolor 2300DL Laser...
Media jam transfer roller
We have a Xerox 6120 which is mechanically identical to the 2430. It was reporting media jams. We determined after removal and careful inspection that the fuser roller and fuser pressure roller had been damaged by what looked like someone attempting to clear a jam with a sharp object. I cannot speak re: the 2430, but the fuser in the 6120 is not a FRU. The construction of the fuser doesn't tolerate any flaws on either surface. There was more paper jammed in the fuser where we couldn't see it until we had the fuser out of the printer. We are shopping for a new printer as the repairs will cost more than we paid for the printer.
Dec 10, 2007 | Konica Minolta magicolor 2430 DL Laser...
Mottled or pimpled paper
may be a fuser roller replace fuser assy
Nov 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Line across paper from Canon iR2016 copier
The line may simply be the optics (mirrors) are dirty. Take a lens cloth or a very soft cloth with 91% alcohol (just alittle bit) and clean them and the exposure glass. That should do the trick. You can also use this method on the rollers as well. Just make sure the fuser roller is cool to the touch first.
Sep 15, 2007 | Office Equipment & Supplies
Konica Minolta magicolor 2300DL Laser Printer Logo
66 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
