Our Olevia TV would not come on when power button was hit. Called New Image TV repairmanand they sent out a gentleman who stated that the main board was "out" and that he had to take the TV with him in order to take out the board and order the part from the manufacturer. That was on December 26, 2008 when we gave a $200 deposit for the repairs. We still have not received our TV and any calls made to New Image are met with the answer that the part has not come in yet from Olevia. I spoke to a rep from the manufacturer o 3/18/09 and he stated that the part would be in by 4/1/09. No luck so far. What can we do about this?
  • 10,594 Answers
Let me know exact model number of your Olevia TV to find required main board however there is Shop Jimmy that have verity of boards for various brands and models.
Click Shop Jimmy to see list of Olevia TV boards and other parts.
You can forward Shop Jimmy address to 'New Image' to purchase main board for your TV.
Hit "add a comment" button for further query / info.
Thanks.
Posted on Apr 19, 2009
My 42" Olevia tv is stuck in stand-by mode.
You need to get the set checked out by a qualified technician. You could either have a problem with the power supply board or the main board. The set needs to be diagnosed to tell which board is causing the problem
Jun 02, 2012 | Olevia Televison & Video
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia HD TV screen goes black but sounds keep coming from the TV and sometime the screen will flicker back and forth like showing image to back to showing no image and sometime when having the TV off...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 11, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Sep 10, 2009 | Olevia Televison & Video
Olevia LT26HVX turns on with blue screen then blanks out
seems like the main-board is having some issues.. the tv's main-board will have to be replace or repair..
Since the manuf. when out of buss.. the only way to get that fix is thru the 3rd party repair center called Amergence Technology in witch they service all Olevia Televisions..
There number is 866-965-3842 im sure they could give you an estimate on the repair cost for you.
Jul 29, 2009 | Olevia LT27HVX 27 in. LCD Television
42" TV has sound but no pictures
yea it sounds like a main-board or inverter board.. sounds like the panel of the television is loosing power and you are still getting sound..
Olevia did go out of buss.. but i know this 3rd party repair center called Amergence technology is offering to repair Olevia's. But the thing is that the whole television will have to get service they don't sell parts so you might want to give them a call and get an idea on the repair quote.. 866-965-3842
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Went on vacation came home Olevia LT20HVK wont turn on red light flashing on power button help''I cant find my owners manual and cant find one online Thank You for any Help
When the red light flashes its a indication that the main-board or the power supply is having some problems..could happen with power outages or power spikes.. this only means the main-board or power supply will have to be repair or replace.. One last thing you want to try is leaving the television overnight unplug from the power and then plug it back in the next day.. if it still reacts the same then the tv has to be service.
Since the Manuf. of olevia is out of buss.. there is a 3rd party service center called Amergence Technology Inc. that is able to service olevia TV's.. there number is 866-965-3842 im sure they are able to give you a repair quote on it...
Apr 04, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
Olevia 747 won't come on
I had the same problem with a 437. It just shut off one day and I could never turn it back on again. I called Syntax Brillian and they told me the mother board was probably shot. They sent me a new TV and took the damaged one back.
Feb 26, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
