Question about Sony Playstation 3 (PS3) Console
Ps3 video screen black can hear sound
Screen is black or if it works it will work for 5-20 seconds then become distorted. i have tried the system reset and replacing hd. please help if you know how i can fix it. i have fixed another ps3 that had ylod. should i reflow the rsx chip? HELP
  • dingbrat Apr 21, 2009
    thanks as listed in the description this has been done it is a problem with the rsx chip
Its easy to fix...press and hold the power button for 10 sec. until it resets its self....the console is set to..be on hi-def and u have to reset the console settings...hope it helps
Posted on Apr 19, 2009
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
After I updated my console and it restarted the screen just stays black and does not do anything. I've tried unplugging and plugging it back in. Still doesn't work. Please help. Brand new system.
Try resetting the video:
While the PS3 is off (solid red led)
Hold down the POWER BUTTON until you hear the SECOND BEEP, quickly release the power button.
Let me know what happens.
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
I turn on ps3 and my screen shows black i tried the thing with holding down the power button and listen for the beats but still no show
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
  • That's it, your video settings are reset and you should be able to choose your input and configure it from there.
  • let me now was this helpfull
May 16, 2010 | Sony Playstation 3 (PS3) Console
My screen is blank and the contollers won't sync up
Sounds like it may be a video problem. Try reseting your system:
1. make sure the system is off
2 hold down the power button for 5-6 seconds, until you hear a second beep
You should be able to use it.
If that doesnt fix it, please let me know the serial number on your ps3, how you are connecting it to your tv (composite, hdmi etc) and the last time it was working and what you have done since.
Dec 05, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will play disk but i have no home start up screen. it appears black although you can hear the sounds as you scroll through the menu
First thing you should try is a manual video reset.
While the PS3 is off (red led) hold down the power button until you hear the SECOND beep, QUICKLY release.
That will reset the video.
Let me know if that works.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
My son dropped my ps3 and it stills turns on but the display screen is black and when i try to turn it off ,i have to pull the cord.
sounds like the main board might have cracked, hope not but its a possibility, we can try a hard reset and see if it fixes the ps3's programing (if its a programing error) when your system is on hold the power button down until you hear 2 beeps (providing this works being you have to turn off the system by unplugging it) Oh have you tried using the power switch in the back? Anyway if u hear the dual beep it signifies that the system has reverted back to the factory settings. Hope this works for you
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
All the connections work the ps3 comes on but then goes black
You may have messed up the Screen-Settings, to solve this try this.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
Oct 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 Graphics Distortion
maybe the tv you are using is not very well compatible with those game since they can be played in HD.try playing thme in another ps3 console or using another tv.
Apr 14, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 blackscreen, but sound! tried all common tricks to reset!
Try your cable connections..either its not conencting properly to the back of your tv. or your cord is fried. Try a different tv and see if it works, if it does, it may be the connectors on your TV.
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
No picture on tv screen.
Had the same problem. When I turned on the console, the screen went a bit fuzzy at first and then remained blank. There was no sound either, but I could still turn it off with the controller. I checked all the connections and even plugged it into another T.V. I have now discovered the problem! The scart connector which came with the PS3 wasn't working properly. Didn't have the prob before because I wasn't using it. Hope that this helps. If not, try holding the power button down for a few seconds after turning on the system. You'll hear a beep noise and the system will try to adjust its AV output or something. Worth a try anyway.
Dec 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
110 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
